Introduction: Tiny Micro-controller Project for Under $2 Bucks
There is much on the internet about getting started with Micro controllers. There is much choice out there, so many ways to program them whether or not you start with the bare chip itself, development boards or more comprehensive SOC(System On Chip) gadgets also many ways to program them.
So for those who are interested, this is one of them.
USBASP + AVR ATTiny85 mini USB dev board (By Digistump)
I like this combination because its a really cheap way to get a project going for a very small form-factor Arduino platform, these chips are so small you can put them in practically anything unlike the unwieldy Unos.
The board im using is a cheap digispark kicksarter knockoff coming in at a whopping $1 on ebay with internation free shipping.
The programmer is the open source USBASP programmer also available for around the same price on ebay or AliExpress
This instructable is the end to end process of getting the dev-board to do something
An easier route is to acquire a real digispark from digistumphttp://digistump.com/products/1
But this project seems to be on hold and these cost $8US
If you have one of these you don't need a programmer as it has and ardudino Micronucleus boot loader pre-flashed to the chip. This means you can use the program directly to the chip from your computer. But the downside of this is that the boot loader takes uses a good portion of available resource on the chip limiting what you can do so for what its worth, this is about USBASP and NOT the Micronucleus
Step 1: Acquire Your Parts
Go to ebay or aliexpress and search up
- "attiny85" for the board
- "usbasp" for the prgrammer and
- "jumber wires" for the wires (optional if you can find some lying around)
Step 2: Put It Together
When your hardware finally arrives start with soldering
Solder the pins breakout pins to that come with the package to the board. This is optional. if you don't have a soldering iron you can just twist the wires on but this is not recommended as the contacts will not be the best
In this example, I, for some reason soldered wires directly the the power terminals but you can use the break out pins to do this also
Step 3: Wireing
Connect the wires as per images. I have used this combination but you can use any you want of coarse they just need to correspond correctly
to the board:
- p0, p1, p2 = green, blue, red
- 5v, GND = red, green (VIN not used)
the connector:
- see diagram for corresponding cable connection
Step 4: Software - VSCode
Now you are wired up you will need to setup your software environment
This includes:
- drivers
- development environment
First download Visual Studio Code. (the best env i have found so far)
You can get this from https://code.visualstudio.com/download
Download and install it
Step 5: Install the PlatformIO IDE Plugin
Click on the extensions button on the bottom left side bar and search for PlatformIO
Install it and reload
Click on the little house button bottom left status bar to open the Platform IO home page if it does not come up automatically after the plugin install
Step 6: Create a New Project
In the project wizard name the project and choose the board
The board must be
Attiny85 (Generic)
The framework must be
Arduino
Step 7: Configure Development Environment for USBASP
Setup the programmer in the PlatformIO project settings file platformio.ini
Add these lines to the platformIO.ini file:
upload_protocol = usbasp
upload_flags = -Pusb
Step 8: Plug in You Programmer
Plug in you programmer
Step 9: Setup Drivers
Your USBASP hardware will need drivers for your computer to communicate with it.
Download Zadig from here
Plug your USBASP usb device into a USB port on your computer
Run the downloaded Zadig program you downloaded
Install the Winusb driver for usbasp
If your system does not recognize the hardware, send me a note and maybe i can help but generally this should work out of the box.
Step 10: Write Your Code
#include
void setup()
// put your setup code here, to run once:
pinMode(1, OUTPUT);
void loop() {
digitalWrite(1, HIGH);
delay(1000);
digitalWrite(1, LOW);
delay(1000);
// put your main code here, to run repeatedly:
Step 11: Compile and Upload Your Program
Make sure you have your ATTiny85 board wired to your programmer and its all hooked up.
Press the keys Ctrl+Alt+U to compile and upload the program
