Introduction: Tiny Mutant Ninja Turtle
I wanted to make some amigurumi tiny mutant ninja turtles. I found these really cool ones on Craftster: Teenage Mutant Ninja Turtles amigurumis for my daughter, but they were too large for what I wanted, so I made up my own. This is what I got. I had fun making these little ones, so I’m posting a small tutorial on how I made them. I work everything on the round, and use a magic ring to start almost everything. If you don’t know how to make a magic ring, here is a great tutorial from PlanetJune.
Mark the beginning of the rows with a piece of contrasting color yarn. The numbers in parenthesis are the number of stitches you'll have at the end of each row.
I’ve tested this pattern a few times, but if there’s a mistake or something that doesn’t quite work let me know so I can fix it.
You can also find this pattern on Ravelry.
Step 1: Stitches Used
Here is a list of the abbreviations I used:
ch: chain
sl st: slip stitch
st: single crochet
hdc: half double crochet
dc: double crochet
Here is a page where there are tutorials for each of these stitches
Step 2: Make the Belly Plate
1: ch 5
2: st in 2nd from hook, st in next 2, st 3 in next. Continue on the other side of the ch, st in next 2, st 2 in next (10)
3: st 2 in first, st in next 2, st 2 in next 3, st in next 2, st 2 in next 2 (16)
4: st 2 in first, st in next 4, st 2 in next, st in next 2, st 2 in next, st in next 4, st 2 in next, st in next 2 (20)
5: st 2 in first, st in next 6, st 3 in next, st in next 3, st 3 in next, st in next 7, st 3 in next, sl st, finish. Leave tail for sewing (27)
Step 3: Make the Shell
1: st 5 in magic ring (5)
2: st 2 in each around (10)
3: st in first, st 3 in next, st in next 2, st 3 in next, st in next 2, st 3 in next, st in next 2 (16)
4: st in first 2, st 2 in next, st in next 4, st 2 in next, st in next 4, st 2 in next, st in next 3 (19)
5: st in each around (19)
6: st 3 in first, st in next 7, st 3 in next, st in next 5, st 3 in next, st in next 4 (25)
7: st in each around (25)
8: st 2 in first, st in next 5, st 2 in next, st in next 5, st 2 in next, st in next 7, st 2 in next, st in next 4. Sl st, finish. Leave tail for sewing. (29)
Step 4: Make the Legs
make 2
1: st 4 in magic ring (4)
2: st 2 in each around (8)
3-7: st in each (8) Finish. Leave tail for sewing
Step 5: Make the Arms
make 2, I used a smaller hook to make them slightly smaller than the legs
2: st 2 in each (8)
3-7: st in each (8)
8: hdc, dc, dc, hdc, st, sl st, finish. Leave tail for sewing
Step 6: Make the Body
2: st 2 in each (10)
3: st around (10)
4: (St in next, st 2 in next) around (15)
5: St around (15)
6: (St in next 2, st 2 in next) around (20)
7: St around (20)
8: (St in next 3, st 2 in next) around (25)
9-12: st around (25)
13: (st in next 3, dec over next 2) around (20)
14: (st in next 2, dec over next 2) around (15)
15: (St in next, dec over next 2) around (10) Stuff.
16: (Dec over next 2) around (5). Sl st, finish
Step 7: Make the Mask
you can make it longer or shorter if you want. You could make the head first so you can measure the length of the mask
1: ch 46
2: st in 2nd st from hook and in next 44. sl st, finish (45)
Step 8: Make the Head
1: st 6 in magic ring (6)
2: St 2 in each (12)
3: (St in next, st 2 in next) around (18)
4: (St in next 2, st 2 in next) around(24)
5-9: st around (24)
10: (St in next 2, dec over next 2) around (18)
11: (St in next, dec over next 2) around (12) Attach mask and eyes, embroider mouth, stuff.
12: (dec over next 2) around (6). Sl st, finish. Leave tail for sewing
Step 9: Assemble
Pin all the parts together to make sure everything is in place then sew.
You can also make a tiny Splinter to go with the turtles
