Introduction: Tiny Pterosaur Glider
About: Airplane enthusiast and dream aviator.
Someone sent me a message about the oldest design I have posted on Instructables. They were having trouble figuring out how to make it. I looked it over. Dang! It was complicated.
If you are inexperienced with paper crafting and/or gliders, you could try increasing the size of the plans by 50% to make it easier to cut out the shapes.* If you do that, you'll probably need to add more weight to the head, such as a pea-sized piece of polymer clay or kneaded eraser.
*I have since scaled up the plans and added them to Step 1. Scale up the piece of paper clip from the micro version—from 2 cm to 3 cm—and the nose weight is not an issue.
The plans are in a PDF file. You will need access to a printer that can handle card stock. In addition...
  1. sheet of 80 lb. / 215 gsm card stock*
  2. glue stick and liquid glue
  3. scissors
  4. hobby knife or razor blade
  5. ruler
  6. large steel paper clip (approx. 2" / 5 cm)
  7. pliers or dikes
*If printing on A4, you may need to scale the image down slightly to accommodate print margins
Step 1: Print and Cut
The plans are in the file below. You'll notice that I like to print on two colors so I can have mix the pieces and have a more visually dynamic glider.
Cut out the pieces precisely.
Step 2: Main Piece, Brace, Neck, & Head
Use a glue stick to attach the neck and wing brace to the top of the main piece. Next, attach the tiny head piece.
Step 3: Ventral Body & Fin
Use a ruler to define the creases on the four tabs of the body pieces. Bend the angles to 90 degrees. Spread a thin, consistent layer of liquid glue over the area where the two pieces will be pressed together to form one. Press together, starting from the back and working up the neck. Do not press the head together.
Cut a piece of paper clip, 2 cm in length.* Add some more liquid glue to the head area. Place the paper clip between the two layers of card stock. Press together and hold until the glue starts to set up.
Apply glue to the four tabs, and attach the ventral body to the main piece. Hold it in place for a minute or so.
Use a ruler to define the rudder, at the back of the vertical fin. Apply liquid glue to the base of the fin and set it in place.
*As mentioned in the Intro, the piece of paper clip should be 3 cm for the larger size glider.
Step 4: Contouring Main Wings & Canards
Use a ruler to define elevators on the canards.* Angle these down about 10 degrees.
Use a ruler to make creases along the wing roots and raise the wingtips by about 7 degrees to make a dihedral wing.
Use your thumb and finger to gently curl the leading edges of the wings down slightly. This will help the wing function as an airfoil. To further enhance the wing's function, pinch along the trailing edges to bend them up slightly, but not across the whole length of the wings. The trailing edge should get flatter toward the middle and can be completely flat by the time you reach the tips.
Step 5: Flights
Look the glider over very closely, and from different angles. The left-right symmetry must be darn near perfect. Make sure the wings aren't twisted or warped in any way. Set the rudder to its neutral position, if not done already.
Test the glider indoors, if possible. If outdoors, the lightest breeze will prevent you from correctly evaluating the flight tendencies of your pterosaur.
When testing, throw it gently and level. If it consistently pitches down, increase the deflection of the elevators (in other words, bend them down). Adjustments must be tiny and incremental. If the elevators get to about 15 degrees of downward deflection without inducing level flight, raise the two elevators at the trailing edges of the main wing a bit.
As you might imagine, the opposite adjustments can be made if the glider is pitching up.
If the glider tends to drift to the left or right, use the rudder to correct it. Again, only small adjustments should be made between each throw. Bending the rudder to the left will make the glider want to go left, and bending it to the right will make it want to go right.
I have not had time to post a video of this pterosaur flying, but it does work! Good luck.
Step 6: Afterthought
Some people think the giant flyers of myth, such as the thunderbird, were based on pterosaurs that somehow survived into the age of humans. I do not believe this to be the case, but it sure is fun to look up at the sky and imagine one of these creatures cruising under the clouds!
