Introduction: Tiny Splinter
After making the set of tiny mutant ninja turtles, I wanted to make Splinter too, about the same size as the turtles. So here’s the result.
I’ve tested this only once, so if there’s a mistake or something that doesn’t quite work let me know so I can fix it.
I work everything on the round, and use a magic ring to start almost everything. If you don’t know how to make a magic ring, here is a great tutorial from PlanetJune.
Mark the beginning of the rows with a piece of contrasting color yarn. The numbers in parenthesis are the number of stitches you'll have at the end of each row.
You can also find this pattern on Ravelry.
Step 1: Stitches Used
Here is a list of the abbreviations I used:
ch: chain
sl st: slip stitch
st: single crochet
hdc: half double crochet
dc: double crochet
Here is a page where there are tutorials for each of these stitches
Step 2: Make the Legs
make 2
1: st 4 in magic ring (4)
2: st 2 in each around (8)
3-7: st in each (8) Finish. Leave tail for sewing
Step 3: Make the Arms
make 2, I used a smaller hook to make them slightly smaller than the legs
2: st 2 in each (8)
3-7: st in each (8)
8: hdc, dc, dc, hdc, st, sl st, finish. Leave tail for sewing
Step 4: Make the Body
1: st 5 in magic ring (5)
2: st 2 in each (10)
3: st around (10)
4: (St in next, st 2 in next) around (15)
5: St around (15)
6: (St in next 2, st 2 in next) around (20)
7-13: st around (20)
14: (st in next 2, dec over next 2) around (15)
15: (St in next, dec over next 2) around (10). Stuff.
16: (Dec over next 2) around (5). Sl st, finish
Step 5: Make the Ears
1: ch 3
2: dc in first st (2nd from hook)
Thread the tail from the tip of the ear to the bottom to sew to the head
Step 6: Make the Head
1: st 3 in magic ring (3)
2: st 2 in first st, st in next, st 2 in next (5)
3: st 2 in first st, (st in next, st 2 in next) around (8)
4: (st in next, st 2 in next) around (12)
5: st in each around (12)
6: (st in next st, st 2 in next) around (18)
7: (st in next 2 st, 2 st in next) around (24)
8-9: st in each around (24)
10: (st in next 2 st, dec over next 2) around (18)
11: (st in next 4 st, dec over next 2) around (15)
12: (st in next 3 st, dec over next 2) around (12). Attach ears, nose and eyes
13: (st in next 2 st, dec over next 2) around (9). Stuff
14: st in first, (dec over next 2) around (5). Sl st, finish. Leave tail for sewing
Step 7: Assemble
Pin all the parts together to make sure everything is in place before sewing.
Chain enough stitches to make the tail as long as you want, then attach it to the body.
Step 8: Make the Kimono
1: ch 21
2: st in 2nd st from hook and in next 19 st (20)
3: ch 2, turn, dc in next 20 st (20 dc)
4: ch 2, turn, dc in next 20 st (20 dc)
5: ch 2, turn, dc in next 20 st (20 dc)
6: ch 2, turn, dc in next 3 st, ch3 3, skip next 3 st, dc in next 7 st, ch 3, skip next 3 st, dc in last 4 st
7: ch 1, turn, st in next 20
You now have a vest. You can leave it like that, or add the sleeves.
To make the sleeves:
1: ch 9 and join with sl st to form a ring (9)
2: st 9 in the ring, join with sl st
3: ch 2, dc in next 9 st, join with sl st. Finish
Stitch the sleeves to the vest
To make the belt simply chain some stitches to make it the length you want.
Step 9: Finish It!
Now you can just dress Splinter up and put him with the turtles!
