Introduction: Tissue Culture Plant Hardening - From Jars to Outside
Have you ever wondered how delicate tissue culture plants, grown in sterile glass jars, eventually thrive under open skies? The process might seem magical, but it’s a carefully guided transition known as hardening. In this phase, these lab-raised plants are gradually introduced to the real world—sunlight, wind, soil, and microbes. It’s a critical step that determines whether these tender plants survive and flourish once they leave the controlled environment. Let's explore how these green wonders are toughened up for life beyond the lab.
Materials Needed :
- TC Plants
- Fluval Stratum
- Perlite
- Fungicide
- Rooting Hormone
- Distilled Water
- IPA 99% Proof (optional)
- Long Handed Twister
- Gloves
- Hydrogen Peroxide 3% proof (recommended)
Step 1: Bringing the Plants Out From the Jars
- Use a clean, sterile area with a paper towel or sterilized surface.
- Wear gloves (preferably sterile or disinfected) to avoid contamination.
- Have tools like forceps, distilled water, and a disinfectant solution (like 0.1% fungicide or diluted hydrogen peroxide) ready.
- Open the tissue culture jar carefully.
- Use sterilized forceps to gently grip the base of the plant clump and take them out.
Step 2: Rinsing the Roots
- Use filtered water in a sterile container.
- Gently place the plant clumps into the water using sterile forceps
- Separate the roots with forceps or fingers.
- Trim the dead leafs (if any) and tissues remaining in the clumps, and clean the agar (gelling agent derived from seaweed) on which the plant lets were grown in labs.
- Carefully lift plantlets and place them on a fresh tissue paper.
Step 3: Treating With Fungicide
- Take Two Glasses of distilled water
- Add a pinch of fungicide powder to the first glass and make a fungicide solution.
- Dip the freshly rinsed plantlets into the fungicide water.
- Ensure the roots and lower stems are fully submerged.
- Let them soak for about 5 minutes — just enough to disinfect without stressing the plants.
Step 4: Rinsing
- After soaking in fungicide solution, use sterile forceps to lift the plantlets.
- Gently place them into the fresh distilled water glass.
- This helps to remove any residual fungicide that might irritate roots or affect the growing medium.
- This rinse ensures the plantlets are clean, safe, and chemical-free before entering the soil or substrate.
Step 5: Preparing the Soil
- Choose a shallow tray with a flat bottom and adequate drainage.
- Mix Perlite with Fluval Stratum in 1:1 ratio.
- The Perlite keeps the medium airy and prevents compaction.
- Fluval Stratum provides essential minerals and promotes root development.
- Combine the two substrates thoroughly.
- Add generous amount of distilled water to make the soil moist.
- The medium should feel light and fluffy.
Step 6: Planting
- Pour a small amount of rooting hormone powder into a sterile surface.
- Use sterile forceps to gently hold the plantlet.
- Dip the bottom root section into the rooting hormone powder.
- Tap lightly to shake off any excess powder — only a light coat is needed.
- Then carefully insert the plantlets into the soil.
- Once planted, gently mist the tray with distilled water to settle the substrate.
- Maintain high humidity (80–90%) for the first 7–10 days. To create this micro climate cover the whole thing with a clear container, the clear container will lock the moisture but permit the light to penetrate.
- Avoid direct sunlight — keep in bright, indirect light. (grow light is highly recommended)
- A temperature of 18-25 degree celcius for the first 10 days is also recommended.
- Do not overwater — only mist when the surface starts drying after 10 days.
- Place them under a grow light.
Step 7: After 10 Days
- You can see the change in leaf-sizes.
- The roots have also developed as I can confirm after I pulled a dead leaf and felt the firmness of the plant in the ground.
- Small fresh areal roots are alsoo visible. This shows the plantlets are becoming stable and responding positively to their new phase of life.
Step 8: Conclusion
From fragile beginnings in sterile jars to standing tall in natural surroundings, tissue culture plants undergo a remarkable journey. Hardening isn't just a technical step—it’s a transformation. With proper care, patience, and understanding of environmental shifts, we prepare them to root deeply, grow stronger, and adapt beautifully to the outdoors. This phase bridges the lab and the landscape, ensuring every plant has a fighting chance to thrive where it truly belongs—under the open sky.
