Introduction: Tissue Pack Secret Compartment
I will show you how to add a secret compartment to a tissue pack
To do this you will need:
PVA glue
a tissue pack
something to hide
scissors
A LOT OF PATIENCE
PVA glue
a tissue pack
something to hide
scissors
A LOT OF PATIENCE
Step 1: Cut All But Two of Your Tissues
You need to cut all but two of your tissues in half. If you want you can have a bigger but less secret compartment. You can do this by cutting it so that you have a bigger compartment and less tissue.
Step 2: Glue It Together
This step helps but it is optional. It stops all the pieces of tissue being moved and revealing your secret object.
All you have to do is glue the parts of tissue together WITH THE WHOLE TISSUES ON THE OUTSIDE so that no one sees your object
Step 3: Let It Dry
This is where you will need your patience. Leave it by the radiator and it will dry quickly. Also don't put it on the floor because otherwise you might tread on it. (like I did)
Letting it dry makes it less likely to fall apart
Step 4: Put Your Object in Between the Big Tissues
Put your object between the two full tissues.
Step 5: Put It in the Packet
Put it in the packet with the object at the bottom. As long as you're careful no one will notice anything.
Step 6: Have Fun
Please comment and favorite.
I have also done a knot tutorial
