Introduction: Titanic Cardboard and Paper Model
The RMS Titanic, launched in 1911, was a British passenger liner known for its luxury and size. It was touted as "unsinkable" but tragically sank on its maiden voyage in 1912 after striking an iceberg. The sinking resulted in the deaths of over 1,500 people. The ship was traveling too fast and had insufficient lifeboats, leading to a high casualty rate. The accident highlighted issues with safety standards at the time and led to changes in maritime regulations.
This is some materials
Cardboard
Paper
Glue gun or white glow
Detail cutter or normal cutter
Mathematical materials like pencil ruler etc
Step 1:
In the beginning please use the cutter carefully otherwise you may forget to cut. A 34 inch inner centre holder will be fitted in it.
Step 2:
As mentioned in the image, its measurements are in the images itself. These are to be made in 7 to 8 pieces and placed on the inner center holder, which will help in supporting the upper floors when they are made.
Step 3:
To make the upper deck in this, make an upper back of 34 inches and 6 inches bigger and after placing the inner holder which you have made, cover the lower portion with hard paper or thin cardboard.
Step 4:
To make floors on the upper deck, you can make floors in a curved shape
Step 5:
In this way you can make 3 floors. If you cannot make it in curve shape then you can make it in rectangle shape. To make it in curve shape make it 11 inch and 3 cm bigger and cover it with paper from above.
Step 6:
3 floors After placing the floors at a distance of 10 inches from the starting area, after making 17 inch long windows on both sides, you can cut the windows if you want or paint them with black colour
Step 7:
There is a little gap left near the windows made on the side, you can make similar windows there and cover them, and if you want, you can leave it open like this
Step 8:
To make the top of the upper part, the measurements given in the images need to be placed on the upper part.
Step 9:
You can make a design like this to cover the back area. You can give the bottom a rectangle shape and the top a square if you want. Or you can do the design that I have made.
Step 10:
To make a chimney on the top area above, make 3 boxes of 7.5 and 6.5 inches and place them in the niche box and build a chimney on them. Keep in mind that the chimney should be a little narrow.
Step 11:
You just make it like this, whatever gap is left on the side, complete it with thin strip and cover it with the help of black, white and golden orange and what is given in the image above, outside side of the chimney.
I hope you liked my Titanic model and I apologize that I could not understand you properly. I hope you liked it. Thank you.☺️☺️☺️☺️
