Introduction: Tmnt Cartoon Ninja Turtle
First off, there are some wonderful instructables on mascot heads that are more informative then mine, so if your looking for a more informative instruction on head mines not the page to find it.
We started the costume with the idea that a latex suit was out of our realm of expertise, and expensive. Fabric and foam was easily accessible to us and we felt instructables could help us with some guidance. So this instructable is kind of paying this great site back.
Step 1: The Head
Step one: we had 6" foam blocks that we glued together ( homedepot sells 2" you can glue together) to get the right size. We drew up a template of the front and side of the head. And also traced our head to insure we don't make a turtle head too big or small. You can use a grinder with a sanding disc and a hacksaw blade to cut off the styrofoam you don't need but you must wear a mask and safety googles. The foam goes everywhere. After rough cutting your shape you next sand by hand to get your exact shape. When your happy you can start gutting the inside like your carving a pumpkin to the exact shape your head can fit in. We cut the mouth out to see and also cut a slit just under the bandana to see which help immensely. Cover the head with spray adhesive and any stretchy material of your chose.
Step 2: The Body
Step two: the body was made by making a wire "cage" around our body that can be welded or duck taped together. Make it as tight as you can without making it impossible to take off or get on. The shell was made almost the same way as the head, foam, shape to size, sand etc. We bent some wire and pushed it through the foam till it came out the other side and we welded it to the frame. Painted the shell black and covered the frame with cardboard and duct tape. We glued packing foam to the outside of the shell to give some added depth to the shell and dry brushed brown to it. Cover the cardboard with felt. It's cheap and looks nice. When making the belt remember paper templates are cheaper then cutting fabric thinking the belts just a straight shape and finding out you just blew $10 because the body is not a cylinder shape. You may want to make straps to hold your shell on, mine fit great till I started walking and sweating. Then the shell started falling.
Step 3: The Arms and Legs
Step three: the arms are EVA foam that cost $11 for a 4x6 sheet. We got two arms and two legs out of a sheet and a half. I wish I had a better explanation to making the arms and legs then just saying copy my pics and work it out. There are weird shapes that make up both parts so if you can't figure it out by looking over the pics email me and I'll try to help you as much as I can.
Step 4: Finished Pictures
Hope this helps somebody. I'll edit as the questions come in. I missed a lot of info like the hands, weapons foam elbow and knee pads. But as I get some free time I'll keep updating this page.
Thanks for looking
Thanks for looking
