Introduction: To Build Circadian Lighting System
Circadian lighting system
wires
pi pico
LED
resistors
push button
ambient light sensor
power adapter
micro USB cable
bread board
Step 1:
first step copy and paste code for lighting system.
second step connect you USB cable to your computer and start running the code/script
test to see if the code works if not check your wiring and script to see if everything is correct.
once you have checked everything run the script and then your code should work.
