Introduction: Toboggan From Old Skis
A pair of old skis are still useful if they still have a flat running surface, a sharpish edge and are rigid enough to form the base for a multi-person toboggan. Here's how one builds such a toboggan.
The objective of this toboggan design is to:
Be as light as possible
Be as strong as possible
Be as fast as possible
Send 2 adults or 12 very small screaming children down a hellishly steep hill
Ingredients:
A pair of knackered adult's skis
A 8'x4' sheet of 9mm birch plywood
Wood glue
Strong contact glue
Double-sided tape
Webbing
The usual workshop bits and bobs and consumables
Utensils:
Circular saw and cutting guide, or table saw
Jig saw
Router with spiral cutter
Plane
Angle gauge
Clamps (you can never have too many!)
Other requirements:
Snow
Screaming children
Step 1: Strip an Old Pair of Straight-edged Skis
Remove the bindings with a large star-point screwdriver and throw them away.
Use a belt sander to roughen the top resin layer to create a glue surface. I went deep enough to remove the faded branding under the resin. This exposes a light plastic material that may in your case be slightly porous, so it you sand this deep, be sure to thoroughly cover the exposed surfaces with polyurethane varnish in the last step.
Step 2: Cut the Plywood Frame
The entire design is based on 15-degree angles, so set your circular saw and angle-gauge to this angle. The sides are 20cm high and the deck is 30cm wide.
Also cut 6 long stringers about 3cm wide from which the bottom ski-mounting rail and the top rabbet-rail will be formed. See the rough cutting plan and the angles at which you need to cut your boards.
I used a cutting guide for a perfect, straight cut with my circular saw. (And my saw also has a laaayzer, dude!)
Step 3: Cut Out Fillets on Side Panels - Part 1
Because this is a repeating pattern, I created a cutting jig from a scrap piece of high-density fibre board (the type they use for cheap wood-effect flooring) and cut my pattern with a jig saw and smoothed it with a drum sander (sandpaper on stick will also do). Remember to leave enough surround on the jig to clamp it to your workpiece such that the clamps do not interfere with the router when you use the jig to cut your fillets.
I used a combination of double-sided sticky tape, self-tapping screws and clamps to hold the jig to the workpiece and completed the one side with a cutting bit on a 1/4" hand-held router.
Use a drum sander (or sandpaper on a stick) to round out the corners, because this side now becomes the cutting jig for the other side.
Step 4: Cut Out Fillets on Side Panels - Part 2
Step 5: Cut Out Fillets on Deck Panel - Part 3
Step 6: Cut Out Fillets on Panels - Part 4
Save the fillet cut-outs for something useful.
Step 7: Glue Stringers to the Side Panels
Clamp it up and let the glue cook.
Step 8: Assemble Left, Right and Deck Panels
Use the sketch below to work out which surface needs to be glued to which surface.
Step 9: Create Front and Rear Gussets
Glue the gussets to the front and rear. When the glue has set, trim the excess from the stringers and run a rounding-over router bit over all the upward-facing and forward- and backward-facing edges, and the inner curves of the gussets. Leave the bottom edges flush, though.
Step 10: Align to Ski's Profile
Clamp the ski flush to flat work surface and place the toboggan rail next to it, resting on top of spacers of the same height as the lowest height of the ski's profile. Decide how far back you want the frame to be on the skis. Trace the ski's profile on to the toboggan rail. Keep in mind that the profile shape is not symetrical along the length of the ski, so repeat this step on both sides with the ski pointing in the same direction.
Use a hand plane or an electric plane to remove the excess material from the toboggan frame.
Step 11: Attach the Skis to the Toboggan Rails
Spread contact glue on both the skis and the the toboggan rails. Wait 10 minutes (or whatever the glue manufacturer says) until the glue is touch-dry. Carefully contact the surfaces and then clamp for a few hours.
I found that the contact glue made the surface of the skis a little mushy because I removed the top resin layer and exposed the slightly porous type of plastic material. I still got a strong (but messy) bond in the end, but I would try two-part epoxy glue next time.
Step 12: Attach Reins
A long piece of packaging webbing is ideal here. You can get this from boxes that large computers / servers / printers get shipped in.
Attach the webbing - folded over once - with countersunk screws and large washers to each ski. Recess the holes in the running surface on the skis so that the countersinks do not stick out. Heat up a screwdriver with a blowtorch and use this to make holes in the webbing, aligned with the screw holes. This will prevent any fraying. For the same reason, seal the webbing's cut ends off with a blowtorch.
Step 13: Paint With Polyurethane and GO PLAY!
Performance Update:
This toboggan put all the other toboggans and sledges on our village hill to shame today (18JAN2013), being the fastest one and the one that went the furtherest. It travels in a dead straight line and a limited amount of steering is possible by pulling on the reins. The overall weight is about 12kg. After many runs and spills, the structure has held out very well - no cracks, no creaks, no splinters.
