Introduction: Tomie Cosplay - With Prosthetics and Special Fx Makeup
I read Junji Ito's popular manga: Tomie, and immediately knew I had to recreate the iconic look, in the most realistic way possible.
If you're a fan of horror manga and the eerie beauty of Junji Ito's work, you're in for a treat. In this tutorial, we'll be exploring how to transform yourself into the captivating and enigmatic character of Tomie.
This is a budget friendly tutorial as well, I made this in under 40$ (3000Rs. in INR), including the wig and makeup products used.
For the prosthetic face
- Plaster of Paris strips: you will need just one bandage roll (2$)
- Mod Podge or any other sealer : matte finish preffered (6$)
- Acrylic Paint (for skin tone and face features) (5-8$)
- Liquid Latex : I used Kryolan (7$)
- False lashes (0.5$)
- Cotton balls
Other materials
- White contact lens (5$)
- Black wig with bangs (10$)
- Basic makeup - Concealer, Red face paint
Step 1: Plaster Face Cast
Make a cast of your face by following the steps below, make sure to cover only one side of your face, as shown in the image.
- Protect the Skin
- Apply plastic wrap or Vaseline to the face to prevent the plaster from sticking.
- Set Up Breathing Straw
- Insert a straw in your nostrils to allow for breathing during the casting process. Make sure it’s secure.
- Cut Plaster Bandages
- Cut the plaster bandages into strips of varying lengths (about 6-8 inches).
- Apply Plaster
- Dip each strip of plaster bandage in a bowl of water, then apply it carefully to the face, starting from the forehead and working downwards.
- Overlap strips to ensure full coverage and strength.
- Build Layers
- Apply at least 2-3 layers of plaster bandages for durability. Allow each layer to set slightly before adding the next.
- Let It Dry
- Once the final layer is applied, allow the cast to dry completely (this may take 30-60 minutes).
- Remove the Cast
- Carefully peel the cast away from the face, starting from the edges. Take your time to avoid breaking it.
- Final Touches
- Trim any rough edges with scissors and smooth out any imperfections from the inside of your cast and strengthen the thinner areas with more plaster
Step 2: Paint Your Face Cast
- Seal the face cast with sealer of choice
- Paint the face according to your skin tone and try to make it as realistic as possible.
- Attach false lashes on the eye
- Add another layer of sealer to fix everything in place.
Step 3: Attaching the Prosthetic to Your Face
- Place the painted face cast over your face and mark the corners to get an idea where it ends
- Use cotton and liquid latex to make a frame around the markings, and attach the prosthetic onto your face.
- Add more cotton and latex to create a veiny transition between the two faces
- Use a fluffy brush and apply concealer on the cotton-latex parts.
- Also, add redness around the area with red face paint.
Step 4: Final Touches
- Do your usual makeup routine: Foundation, eye makeup, lashes, and try to keep both faces as similar as possible.
- Add a birthmark under your eye to resemble Tomie's look
- I suggest wearing a wig cap or a bald cap before you start the previous step to get your natural hair out of the way, as well as to make it easier to put on the wig.
- Wear the black wig, make sure the bangs go above both your real face, as well as the prosthetic.
Anddddd you're done! Hope you have a blast trying out this cosplay! do tag me on instagram @spfxbyser if you recreate or if you have any doubts!
