Introduction: Toothpaste Press
My mother needed a way to get the toothpaste out of the tube after it had been used a lot. My solution was to make a tool that squeezed out the toothpaste for her.
Computer
TinkerCad
PrusaSlicer
3D printer
Filament
Step 1: TinkerCad
1. Open the Tinkercad app and sign up or log in.
Step 2: 3D Project
2. Make a new 3D project.
Step 3: Create Design
Design and customize your toothpaste press. Make sure you are using the correct measurements for your toothpaste! (If you need to be in inches, go to settings, then units, and switch to Imperial units.)
Step 4: Export
Export your file as a .STL file.
Step 5: Open PrusaSlicer
Open the PrusaSlicer app with your 3D printer.
Step 6: Import
Click on the file button on the top, then press import. Find your .STL file and upload.
Step 7: Change Settings
Change the filament, supports, print settings, and infill for your desired outcome.
Step 8: Slice and Export G-Code
Press "Slice Now" and "Export G-Code"
