Introduction: Toothpaste Tube Holder
Make this simple little device to hold your toothpaste tube where you want it.
Step 1: You Will Need:
Toothpaste (tube)
Clothespin
Step 2: Flatten Tube.
Flatten and fold the tube so that all the toothpaste is at the end.
Step 3: Dismantle the Clothespin.
Step 4: Here's the Trick!
Put the spring in backwards. It will take some fiddling, but it works best if the crossbars are in their slots, rather than having the spring part in the concave sections and the crossbars "in back of " their slots.
The spring coil will be a little in front of the clip cave section.
Step 5: Put the Clothespin on "backwards".
The reason for turning the spring around is so that the long end of the clothespin doesn't stick out as much.
Step 6: Done!
Now you can lay it flat or stand it up like it is here.
