Introduction: Toothpick Shooter
These are complete instructions for making a toothpick shooter. A DC motor and a wheel is used for the firing mechanism, the servo is used for automatic reloading and as the name suggests toothpicks are used as bullets
For creating base-
Marker
Ruler
Set Square
Sun Board
Cutter
Superglue
Making firing mechanism and magazine -
DC motors
Battery Holder
18650 Rechargeable Battery
Double-Sided Tape
Wires
Soldering kit
Heat shrink
Switch
Sun Board
Glue gun
Wheel
Making reloading mechanism
3D printed parts
-Bracket
-Gear
-Pusher
-Magazine
Servo
Wires
ESP 32
Micro USB Cable ( Data Cable)
Toothpick
Superglue
Bullets-
Toothpick
Step 1: Make the Firing Mechanism and Base
-Take Sunboard and mark the dimensions as specified in the figure with the help of a marker, Ruler, and Set square (to make perpendicular lines)
-Use a Cutter to cut the pieces
-Take the base and mark an axis along the length ( for Reference )
-Insert the DC Motor in the hole and fix it using the hot glue gun.
-Attach the wheel
-Mount the board with the motor on the base using super glue such that the wheel is aligned with the reference axis
-Use small triangular pieces of sunboard to reinforce the vertical board
- Make the connections for the motor, battery, holder and switch
Step 2: Print 3 D Parts
Use the above files to print the parts
Step 3: Assemble Everything
-Take the 3D printed part and fix it to the base.
- Place the magazine just before the wheel using super glue such it is on the reference axis and the groove is facing the base
- Fix a toothpick at pusher such 3 cm of the toothpick is projecting outwards
- Mount the gear on the servo motor using super glue
- Insert the pusher in the bracket
- Attach servo on the bracket using screws or super glue
- Fix the brackets using super glue such that the toothpick is on the reference axis
Step 4: Code the ESP32 and Attach Servo to It
- Use Micro USB Cable to upload the following code -
#include <Servo.h>
Servo servo_2;
void setup()
servo_2.attach(4);
void loop() {
servo_2.write(180);
delay(2000);
servo_2.write(0);
delay(2000);
- Make the following connections
Servo's signal wire to Pin 4 of ESP32
Servo's live wire to 3V3 ESP 32
Servo's Ground wire to GND pin of Arduino
- Fix the Arduino on the base using double-sided tape
Step 5: Test the Gun
- Load the magazine with toothpicks
- Use A to B cable to power the Arduino
- Turn the switch ON
