Introduction: Torque Bar Spinner
In this indestructible i be showing you how to make a torque bar spinner
Step 1: First Pick a Design That You Like
Step 2: Pick the Material You Will Be Using
You could use plastic, metal and wood or 3D print
Step 3: Cut
cut material to rough size you whant
Step 4: Drill
Drill 3 hole one for a bearing wheel and the other for weight or one in the center the hole should be slightly smaller than the bearing then file to snog.
Step 5: To Shape
Then grind (if steel) and file to the end shape
Step 6: Finsh
Add the bearing to the center hole and the weight to the outer holes
Sanded smooth and vanish
