Introduction: Total Video Converter
I always find myself needing to convert
video files between popular common and HD video formats like MTS, MP4, AVI, MKV, MOV, WMV, FLV and more for my work requirement. And sometimes, I need to extract audio files from videos and convert audio formats between MP3, M4A, WMA, WAV, FLV, AAC, AC3, etc. The other day I was converting 3D video to MOV format for a main meeting to make a movie show. While I just have 3D format, finally this professional and easy-use tool helps me. And with that in mind I recommend you this Total Video Converter.
There are three key features:
1. Convert video to any popular video or audio file format
2. Convert video or audio for any popular digital device
3. Customize the output video or audio files and edit it easily.
It is really convenient that I will never need to make another converter again. Just this tool I can get videos that I wanted. Also you can use this video converter.
Below is the using step:
Step 1: Add Video or Audio Files
After loading this software, click
"Add file(s)" icon button on the toolbar in the main window to browse your computer and open the local video and audio files one by one you want to convert. Or, you’re able to directly drag video files from your computer to the program as well.
Step 2: Choose Output Format
Click "Profile" drop-down arrow
to open the "Profile" window. Here you can choose different output formats for each source video/audio file. Or input the format name to the quick search box and select one of the corresponding formats as the output format.
Step 3: Edit Videos
Customize your videos with multiple editing features, just open the edit
window and start to personalize the videos.
a. Choose the file you want to rotate, and then click Edit. Select "Rotate" column to rotate your video.
b. Click "3D" icon button on the toolbar to open the edit window, here you would check "Enable 3D Settings" option to select the needed 3D mode for your output 3D videos, like Anaglyph 3D mode or Split Screen 3D mode.
c. Check "Keep Aspect Ratio" option to adjust the video frame, like Original, Crop area, 16:9, 4:3. And change the zoom mode according to your need, like Letterboxing, Pillarboxing, Windowboxing.
d. Click "Effect" column, you're enabled to adjust the Brightness, Saturation, Contrast, Hue and Volume for a better video effect.
e. Choose the options to enhance your video quality.
f. Image and text watermark are enabled here. You can customize the transparency, position and size of the watermark. For the text watermark, the font style, size and color are adjustable.
Step 4: Clip Videos
Click "Clip" icon button on the toolbar in the main window to open the "Clip" window, then you can trim the video length and clip video to several segments. Or you can click "Merge" button to merge the selected video clips into a new single file.
Step 5: Start
Well, you can start to convert your video.
