Introduction: Towel Hangar
Step 1: Draw an Idea on Paper
Item you need
Paper
Pencil
Glue
Scrollsaw or fretsaw
Plywood
Send paper
Any colour spray paint
Hand or electric drill wit 3mm beat
Screw 2
Hook
Towel ring
Step 2: Stick and Drill
After draw your idea on paper stick it on plywood size about 10"x8" using paper glue
Then make hole using 3mm drill on part witch you want to cut out
Step 3: Cutout
Now cut out unwanted area witch you drilled in last step using scroll saw or handsaw
I did used delta multi speed quick Chang scroll saw
Step 4: Paint
Now rub your craft on send paper to make it smooth
Clean it with cloth or brush
Then spray with primer and then choice of your colour let it dry
Step 5: Fix Towel Ring
Now make 3 hole 2 for fix on wall
1 for fix hook
Fix hook at bottom hole and hang towel ring on it fit your craft on wall with 2 screw
Now your homemade towel hangar is reddy
Thank you for your time for looking my craft
And sorry for any mistake in my English
