Introduction: Tower Led
Step 1: What We Need
1 Threaded Rod
10 Leds (20 for beter result)
1 capacitor 63V 10uF
2 resistors 10k
IC LM3914N
acrylic sheet 8mm
acrylic sheet 4mm (option for the for the box that contains the circuit)
2k pot
50k pot
100k resistor (option. The resistance value can change it depend on your stereo)
2 diode zener
veroboard
wire
Other material:
hot glue
pliers long nose
30 nut for the Threaded Rod (on my project)
Drill
sander p100 (for the edge)
Step 2: Schematic
5k for 1.5v
85k for 9v
110k for 12v
Step 3: Cut Acrylic and Wood and Drill It
You can cut the acrylique with a saw or electric saw (not fast you can melt acrylic). drill the acrylique,use drill 5mm for the LEDs and make a hole around 0.5 to 1 cm.
cut your wood to make a stable base to hold the tower. for my project I use a wood 15 cm by 25 cm and 3cm thick
the hardest time, drill the holes for the rod. holes must be in the same place on all acrylic sheets
Step 4: Finiching and Result :)
welding the anodes of the LEDs to have a common positive wire
connect all led to the board.
remember: led 10 is connected on pin 1 and the first led is connected on pin 10
Full Spectrum Laser Contest
123D Circuits Contest
13 Comments
5 years ago
How do you make it flash in sync with the music?
Reply 5 years ago
Hi Kelvinzhang
the LM3914N compares the input voltage(from audio pin 5) to an external voltage to light up the right LED here the datasheet for the ic http://www.ti.com/lit/ds/symlink/lm3914.pdf
hope i can help and sorry for the late
6 years ago on Introduction
Hi im a pretty big nooby at all this, how are you powering the leds?
Reply 6 years ago
Hi menbins102
I use a 12V adapto at 0.005 mA
Is there someway to make this minus the cap? I have all the parts except the capacitor, and am wondering what the purpose of the capacitor is and if it's necessary, or if it can be replaced wiht something else.
Reply 6 years ago on Introduction
Can't the zener diodes be replaced with just normal diodes? I can't find a reason for them to be zener diodes.
you can not replace the zener diodes with normal diodes. I think you can you obtain for cheap on ebay. the zener diode is used to regulate the voltage
Reply 6 years ago
hy neutralityy I don't know exactly what the cap does, but its not realy necessary.
What are the specs of the zener diodes you used? What wattage and whats the breakaway voltage? Are both diodes identical?
7 years ago on Introduction
Great job. Did you have wait till the cat fell asleep before starting your project? I had cats and I am still finding lost project parts or toys (Depends
on your purrrrspective)
they take my components as played and lost :). they like to sleep on my worktable and I must find a place to work
nice.
thanx
