Introduction: Toy Car
These instructions will be used to create a Toy car with the ability to move forward and create sound and light.
To start you will need the two halves of the car that is the top and bottom, the axles and wheels, the cpx, and the three wires to connect it to a battery, and a computer to create the code.
Step 1: Lets Make the Body
First, we want to make the car one piece, start by gluing the top to the bottom making sure it is properly aligned.
in this step, we may as well finish the body as well. take the two axles and put one axle through the two holes where the front and back wheels would be after which glue to wheels to each end of the axle.
Step 2: Coding the CPX
we will start with the basics of the code.
for this project, you will need the libraries - Bus device, circuitplayground, and motor.
make sure your cpx is properly plugged in so when it's saved it works.
Step 3: Importing the Libraries
so that all the code can properly run and to help in the making process we will import the libraries first.
by typing the code within the image you have successfully imported all the libraries needed to run the code.
Step 4: Two Button Setup
For our car we use the two buttons on the CPX both have the same function but allow for the pressing of a different button to still get the same result.
for this, we will use a while true loop
Step 5: Shine Bright
next, we will add lights to the CPX
these will be red and blue to mimic that of a police car.
the first image defines the base setting for our lights.
the second image will play either red or blue lights depending on their respective button
Step 6: Lets Make Some Noise
Now we will get our cpx playing a tone while it moves
these will play a tone on button press
Step 7: FORWARD!
adding this code will allow your car to move forward for 5 seconds
now that you are done with the code press save and unplug the cpx from your computer
Step 8: WIRING
When wiring you have three wires for this case they will be red yellow and brown
make sure before connecting the wires to the cpx you run them through the hole on the bottom
Brown - the ground wire
yellow - the function
red - the output
these correspond to the words on the CPX itself
after this is done you may now place the cpx on the top of the car and the motor under or on the back.
Step 9: Gotta Go Fast
now we have to glue the motor to the bottom of the car making sure it touches the ground (if the wheel attached does touch the ground the car will not move) be careful not to place the motor the wrong way or you might end up going backwards.
