Toy Cruiser
Intro: Toy Cruiser
This is an easy to assemble toy car made using lots of high-tech tools. Once you 3D print, and laser cut your parts, the rest can be zip tied and bolted together in minutes. I was initially planning on making more of a hot rod. However, thanks to the slow speed of the servos, it turned out to be more of a cruiser. This vehicle has a slow smooth ride, which makes it the perfect motorized platform for all kinds of applications. For instance, it makes a great camera dolly (for silent films and music videos), and a suitable robot base. Nonetheless, it was a fun exercise in state-of-the-art personal fabrication.
Check out my book Homemade Robots for more robot projects!
STEP 1: Go Get Stuff
(x1) An 11" x 6" laser cut bracket (file attached below)
(x2) 3D printed servo wheel
(x2) Parallax continuous rotation servos modified for direct drive
(x1) 3D printed wheel and pivots (printed at precisely 1/4 the model size)
(x1) 1/4" x 2" stainless Steel rod
(x1) 4 x AA battery holder
(x4) AA batteries
(x12) 4" zip ties
(x8) 12" zip ties
(x2) 4-40 x 1/2" nuts, bolts and washers
(x1) 220 Sandpaper (optional - not pictured)
(x1) Polycrylic stain (optional - not pictured)
STEP 2: Sand and Stain (optional)
Sand both sides of your wooden bracket and wipe them off.
Coat one side with wood stain. Wait for it to dry, sand it lightly, and then coat it again.
When the first side is dry, repeat on the opposite side.
STEP 3: Drill
Repeat on the other servo.
STEP 4: Zip Tie
STEP 5: Press Fit
STEP 6: Attach the Wheel
Slip the wheel into front fork of the laser cut bracket and zip tie the pivots firmly in place.
STEP 7: Attach the Servos
Make sure the servos are on the same side of the bracket as the pivots.
STEP 8: Battery Holder
Line up its mounting holes with holes in the bracket and fasten it in place with the 4-40 nuts, bolts and washers.
STEP 9: Wire It Up
Twist together the red wire from the servo on the left to the black wire of the servo on the right. Connect both of these to the red wire from the battery holder.
Twist together the black wire from the servo on the left to the red wire of the servo on the right. Connect both of these to the black wire from the battery holder.
Solder both pairs of wire together to make a more reliable electrical connection.
STEP 10: Clean It Up
STEP 11: Insert Batteries
STEP 12: Use
I think it will work well as a generic robot base as well.
14 Comments
MrJoel 6 years ago
awesome one!!!!!!!!!!!!!
mykes1 7 years ago
could you make it big enough to hold a 280 pound grandfather
Reese_Rules 10 years ago
If you enlarge this project could it become a motorized skateboard? If so do you think it would have a chance of holding a 90 lbs child?.
--------------------- 10 years ago
Ps its worth looking at my ones a the you will see how similar they are
white dragon 11 years ago
THNX
randofo 11 years ago
oldmechanic 11 years ago
ilpug 11 years ago
thecrazymagnetman 11 years ago
Flyinseamnky 11 years ago
Arghus 11 years ago
