Introduction: Track 2D Movement Using Arduino Ultrasonic Sensors and Visualize in Unity
please watch the video for better demonstration.
we will be using two ultrasonic sensors, one to track horizontal movement and the other to track the vertical. the key is in placing the sensors and using a tool(a shoe box in our example) that will remain at a visible range to both sensors at the top, bottom , left and right edges. and the whole process is visualized by moving an object in unity.
Step 1: Get the Parts
1- 2 ultrasonic sensors
2- 8 female-male wires
3- 4 male-male wires
4- 2 shoe boxes
5- breadboard
6- pushpins
7-small screw driver
8- a box cutter
Step 2:
1- cut the side wall of the shoe box and using the push pins place it on top to hold our y-axis ultrasonic sensor
2-make holes for our sensors, for me I drew each circle of the ultrasonic and used a box cutter . you need one on the side wall for the x-axis sensor and the other on the top wall for y-axis.
3- mount your arduino to the side of the shoebox and place your breadboard on top. we need them to be half way between the two sensors to make wiring easier.
4- connect your ultrasonics to the arduino and breadboard, each ultrasonic will need 4 wires..a ground, vcc, and two digital pins for trig and echo I used 5 and 4 for the x-axis , 7 and 6 for the y-axis.
(schematic will be available soon)
Step 3: Lets Write Arduino Code
the code simply will read the two sensors reading make it into a string and send it to unity for processing. however, instead of reading values in centimeters we will do it in millimeter to provide a smoother movement in unity by making a slight change in the formula
const int TRIGX = 5;
const int ECHOX = 4;
const int TRIGY = 7;
const int ECHOY = 6;
void setup (){
Serial.begin(9600);
pinMode(TRIGX, OUTPUT);
pinMode(ECHOX, INPUT);
pinMode(TRIGY, OUTPUT);
pinMode(ECHOY, INPUT); }
void loop (){
int dataX = GetUltra(TRIGX,ECHOX);
int dataY = GetUltra(TRIGY,ECHOY);
Serial.flush();
Serial.print( dataX );
Serial.print(','); Serial.print( dataY );
Serial.println();
delay(20);
double GetUltra ( int trig , int echo){
digitalWrite(trig , LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(8);
digitalWrite(trig, LOW);
double distance = ( pulseIn(echo, HIGH) )* 343.2 / 2000; return distance;
Step 4: Lets Write Our Unity Code
please make sure that your unity projects allows serial Communication by
1- edit>project settings>player> scroll down to optimization and change api compatibility to .NET 2.0
2-now we change the main camera into Orthographic and set the size to 5 and finally change it's position to
x = 9 , y = -6
3- create a cube and attach the script to it
using UnityEngine;
using System.Collections; using System.IO.Ports; public class axis : MonoBehaviour {private Vector3 temp;
private SerialPort stream = new SerialPort(@"\\.\" + "COM11", 9600);
// Use this for initialization void Start () { stream.Open(); stream.ReadTimeout = 25; StartCoroutine(readString()); } // Update is called once per frame void Update () { } IEnumerator readString() {
while (true) {
if (stream.IsOpen) {
try {
string value = stream.ReadLine(); string[] values = value.Split(',');
float x = int.Parse(values[0]); float y = -1 * (int.Parse(values[1])); x = x / 10f; y = y / 10f; temp = transform.position; temp.x = x; temp.y = y; transform.position = temp;
} catch (System.Exception) {
yield return null;
