Introduction: Traffic Light Control Using Arduino
In this tutorial, we will take a look at building an Arduino traffic light circuit. very simple circuit that’s great for beginners
This is a great beginner project if you have only just bought your first Arduino or looking at buying one. Check out the equipment list a bit further down the page for everything you will need in this project.
Even though the traffic lights are extremely basic, it’s a great way to introduce yourself or others to the basics of electronics and coding.
This tutorial will provide you with a basic understanding of connecting circuitry to the Arduino and show some basics of coding.
- Arduino UNO ×1
- LED Traffic Lights Signal Module ×1
- male to male jumper wire ×4
Step 1: Schematics
- Connect the LEDs to the Arduino using the following connections:
- Red LED: Pin 2
- Yellow LED: Pin 3
- Green LED: Pin 4
- If you use 5mm LED Connect a 220-ohm resistor to the longer (anode) leg of each LED and the other end of the resistor to the ground (GND) on the Arduino.
Step 2: Write the Arduino Code
int red = 2;
int yellow = 3;
int green = 4;
void setup(){
pinMode(red, OUTPUT);
pinMode(yellow, OUTPUT);
pinMode(green, OUTPUT);
void loop(){
digitalWrite(red, HIGH);
delay(15000);
digitalWrite(red, LOW);
digitalWrite(yellow, HIGH);
delay(1000);
digitalWrite(yellow, LOW);
delay(500);
delay(1000);
delay(500);
delay(1000);
delay(500);
delay(1000);
delay(500);
delay(1000);
delay(500);
digitalWrite(green, HIGH);
delay(20000);
digitalWrite(green, LOW);
delay(1000);
delay(500);
delay(1000);
delay(500);
delay(1000);
delay(500);
delay(1000);
delay(500);
delay(1000);
delay(500);
- Open the Arduino IDE on your computer.
- Copy and paste the code into the IDE.
- Select the correct board and port from the Tools menu.
- Click the "Upload" button to upload the code to your Arduino.
Step 3: Test the Traffic Light System
After uploading the code, you should see the LEDs simulate a traffic light system with the following sequence: Red -> Red and Yellow -> Green -> Yellow. The cycle will then repeat.
Step 4: Troubleshooting
If the circuit is not working as expected, double-check your connections, resistor values, and the code. Make sure the LEDs are connected with the correct polarity (longer leg to the resistor).
Step 5: Expand and Experiment
Feel free to modify the code or add more features to the project. You can include a pedestrian signal, add a button for manual control, or use sensors for a more advanced traffic light system. Good luck with your Traffic Light Control System using Arduino!
