Introduction: Traffic Light Controller
This is a simple circuit of a traffic light controller , this is designed using the tinkerCAD software .
This is a simple working model for the beginners who are learning Robotics . This is my 2nd working model , it is easy to design and work in it .
Step 1: Required Components
Below the following are the components required to make a Traffic Light Controller :
1] Breadboard 1No.
2] Arduino 1No.
3] RGB LEDs 3 No.
4] Resistors 3 No.
5] Connecting Wires 4 No.
Step 2: Assembling
First take 1 Breadboard small and Arduino , now rotate the Breadboard 180 degrees .
Step 3: Connecting Resistors
Take 3 Resistors and rotate it to 90 degree
Now connect it to the breadboard ,Terminal Strips 4th Hole Row [d] to 2nd Terminal Strips 1st Hole Row
Connect the 3 Resistors as shown in the images .
Step 4: Connecting LED Bulbs
Take 3 LED Bulbs in RED , YELLOW and REEN in colors , and rotate it in 90 degrees towards right .
Connect the LED bulbs to the Breadboard as shown in the second image .
Step 5: Connecting Wires
Now, here we are going to connect the wires .
Follow the given video for connecting the wires .
Step 6: Coding
In the whole process coding is the most important one and the last step . Now you to code the program and run them .
This is the code done me to run the Arduino IDE.
// variables
int YELLOW = 9;
int GREEN= 10;
int RED = 8;
int DELAY GREEN = 5000;
int DELAY YELLOW = 2000;
int DELAY RED = 5000;
// basic functions void setup()
pinMode(GREEN, OUTPUT);
pinMode(YELLOW, OUTPUT);
pinMode(RED, OUTPUT);
void loop()
red_light();
delay(DELAY_RED);
yellow_light();
delay(DELAY_YELLOW); delay(DELAY_GREEN);
green_light();
delay(DELAY_GREEN);
void green light()
{ digitalWrite(GREEN, HIGH);
digitalWrite(YELLOW, LOW);
digitalWrite(RED, LOW);
void yellow_light()
digitalWrite(GREEN, LOW);
digitalWrite(YELLOW, HIGH);
digitalWrite(RED, LOW); }
void red_light()
digitalWrite(RED, HIGH);
