Introduction: Trailer Dolly
I have recently decided to make a trailer dolly to move my jet ski trailer. It is very simple to make using an old bed frame and some other metal parts.
Tools.
-welder
-angle grinder
-bed frame
-two smallish wheels
-2 long bolts and 6 nuts
-steel pipe
-two square pipes that fit into each other.
-a trailer ball and nut.
Step 1: The Base
I cut a small piece of a bed frame about 1ft long and welded the two bolts to either end.
Step 2: The Handle
Next, I cut two pieces of pipe, 1 ft, and 4ft, and welded them together to create the handle. I then welded that to the base.
Step 3: The Pipe
Sorry for the bad picture, but basically I cut at an angle to the middle of the bigger pipe, and then welded that to the base. Then I welded the nut inside the smaller pipe. The smaller pipe can be adjusted for bigger or smaller trailers. I just used a screw to hold it up.
Step 4: Final Step
Finally, I added the wheels. I put one nut all the way at the end, then the wheel, then two more nuts to lock it in place. and it finished. Enjoy
