Introduction: Wifs
I’m Stephanie Minne , I study New Media and Communication Technology (NMCT) at Howest (Kortrijk Belgium). At school we got the assignment to make a device with a webpage. You can take a look at my portfolio.
I have chosen to make a train seat whit a sensor in it. The sensor will detect if there is a person sitting on the seat.
Step 1: Required Materials
For this project several materials are needed.
Pressure sensor (fsr 400) = €9,20/unit
Raspberry Pi 3 = €37,95
RGB leds = €0.5 /unit
Resistor (470 ohm) = €0.10 /unit
LCD display = €2.44 /unit
Mcp 3008 = €29,00 /unit
Sn74hc595n = €1,20 /unit
Potentiometre = €1,15
Step 2: The Circuit
The hardware is pretty easy.
As can be seen on the schematic, I used a 74hc47 for my leds. The reason for that is because my raspberry Pi don’t has a lot of pins. The disadvantage of this, is that you only can make the led red or green. You don’t have a pwm signal to make different colors.
The raspberry Pi doesn’t have analog input pins. So I need a mcp 3008. This converts an analog signal to a digital. The pressure sendor is put on the channels of the mcp 3008.
Step 3: Make a Database
In this project a mysql was used as database server.
The table occupation has information about the sensors. It capture where a person sits
on a train seat. From the moment a person sits on the seat the first data will be written in the table. All the data will be written in the table with the exception of the datetimeEnd.
In the table route comes data about the different routes that a train does.
The table has two values: one for the normal datetime and another for the real datetime.
The datetime normal is the time that the train is at a stop theoretically. The datetime real is the time that the train is at a stop for real. This time is with the delay inclusive.
Every train has a clear and unique reference, composed by letters (p.e. IC stands for Intercity train) and numbers (p.e. 4565 is the train from Brussels to Antwerp).
And every type has its own accommodation. For example tables, rubbish bins.
Step 4: Code It!
De base code of the sensors is written in Python. There are
2 kinds of code. The first one is for the sensors. The second one is for the webpage. The web page data is written in Python, Flask, JavaScript, HTML and CSS.
The sensor
Every component has his own class. All the different classes are used in the test.py.
The web
The web code is written in Python and Flask. For the header a template is used. The other piece of the page has its own html page.
The file structure
- The test file can be found in the directory sensor.
- The classes are located in the directory models.
- The directory sql contains the dump of the train database.
- The directory web contains the index.py. This is the Flask page. This file has to be run in order to run the webpage.
- The templates directory contains the html pages.
- The directory static contains images, fonts and the css files.
Step 5: Make It Beautiful
There are different ways to make a beautiful train. I have chosen
to make a 3d print of a train.
The seats.
A small hole has to be foreseen in the seat as the sensor needs to be put on the seat. The leds are fixed on top of the seat.
The wagon.
There are a few important features in the wagon. At first there must be little holes in the floor where the seats come.
- The sensor and the cales of the leds should go though these holes.
- In the sidepanel there is a hole to fix the LCD display with the information on the IP address and the number of free seats.
- The Raspberry Pi should be located on the back out of sight.
!Attention: the 3d print is printed a bit smaller so an extra 3 or 4 mm for the holes must be foreseen!
