Introduction: Transfer Sensor Readings to Google Sheets Using Micromis Base V1 Board
In the course of this tutorial, we will make a device design that, using the Micromis Base V1 board, will send cyclic temperature reports directly to Google Sheets. We will establish communication with Google Sheets through a built-in GSM modem, which we will control using AT commands. To completely reduce the use of external components for temperature measurements we will use the LM75 temperature sensor built into the Micromis Base V1 board.
Making the tutorial requires a Micromis Base V1 board, a GSM antenna with a U.FL connector, and an active SIM card.
The environment created in this project can be used to generate interesting charts and reports created from data uploaded to spreadsheets.
- Micromis Base V1
- Micromis Power Shield
- GSM antenna with a U.FL connector (supporting frequencies in the range of 800 to 1900 MHz)
- NanoSIM card
Step 1: Configure the Hardware Part of the Project
To start the project, first connect the GSM antenna to the U.FL connector on the Micromis Base V1 board. Next, insert an active nanoSIM card with sufficient funds for connecting to the internet. Finally, connect the Micromis Base V1 and Micromis Power Shield boards by placing one on top of the other.
Step 2: Configure the Arduino IDE Environment
In order to run the program created in this tutorial, you will need the Arduino IDE environment with a set of external ESP32 boards installed. We recommend using an Arduino IDE no older than version 2.0.0. In order for the program to be properly uploaded to the Micromis Base V1 board, select the ESP32 Dev Module board in "Tools" > "Board" and choose the port to which the Micromis Base V1 board is connected.
Step 3: Create a Google Sheet and Add an Access Point to It
In order to create the project presented in the tutorial, it is necessary to have a Google account and access to Google Drive. Creating a sheet to which we will send data is very simple and requires only a few steps, which are discussed in the section "Setting up Google Sheets"
Google Sheets allows you to create free access points that allow you to add any data you want to the sheet's fields. To create an access point, we need a Google account and access to Google Drive. At the very beginning we create a Google Sheets document we can give it any name.
Already in place ofURL in the browser should appear a string of characters that we will use to transfer data. The most important part of the whole URL is the ID of our sheet contained in it. In our case, the URL is:
https://docs.google.com/spreadsheets/d/1e6NvGfexudk5Ta_zua-NnewG8E28TEEAe75JnFdRt1k/edit#gid=0
And the ID itself is:
After obtaining the document ID we can move on to naming our worksheet, this element can be useful when we want to transfer several types of data to one document, in our case the name of the worksheet is "Temp_log"
Depending on your preference and needs in the document, we can create headers for specific columns. In our case, we want to send data such as temperature, date and time and the ID of a specific sensor in case the same data will be sent by several devices.
Of course, there is nothing to prevent you from sending far more data to the sheet, the column header names given here are adapted to the example discussed in the tutorial
After giving a name to the sheet in which the sensor data will be stored and creating headers, we can move on to creating an access point, and to do this we need to go to Extensions > Apps Script
After clicking on Apps Script in the browser, a new tab should open in which we can add our own scripts that will be processed and added to the sheets. To create a script we will need the ID of the document and the name of the sheet, in our case:
ID =
Sheet name = Temp_log
The code itself for placing data in the sheet is extremely simple and consists of only a few lines of code. At the very beginning, values such as the ID of the document and the name of the sheet are assigned to the variables, then the program analyzes the variables that are uploaded, and at the very end there is a command that adds the uploaded values to the sheet. The following code should be pasted into the program place where the empty function is located by default.
var sheet_id = "1e6NvGfexudk5Ta_zua-NnewG8E28TEEAe75JnFdRt1k";
var sheet_name = "Temp_log;
function doGet(e){
var ss = SpreadsheetApp.openById(sheet_id);
var sheet = ss.getSheetByName(sheet_name);
var temperature = e.parameter.temperature;
var datetime = e.parameter.datetime;
var id = e.parameter.id;
sheet.appendRow([temperature,datetime,id]);
If you use an identical column layout in the code, you only need to change the document ID and the sheet name. The sheet ID is changed in the first line, which currently has the value:
For example, for ID "1111aaaa1111" would be:
var sheet_id = "1111aaaa1111";
The name of the sheet is placed in the sheet_name variable, in the second line of code:
For a sheet named "Temperature_reader" would be:
var sheet_name = "Temperature_reader";
Correctly added code should look like the graphic below:
After adding the correct values to the variables, we can proceed to generate the access point. To do this we need to click on the blue button "Implement" in the upper right corner of the page. After clicking, we will be shown three options:
- New deployment
- Manage Deployments
- Test Deployments
Since we don't have an access point created yet, we click "New Deployment", after a while a dialog box should open where we click on the pinwheel and select "Web Application".
After selecting the web application, several fields will appear in the configuration panel:
- Description
- Execute as
- Who has access
Deployment description is an individual matter and does not need to be filled in. For the "as" field we check "I", so that all data sent by devices will be identified as data added from our account. For the "Who has access" field, we check "Anyone" so that the data can go to the sheet easily, without having to log into a Google account first. Properly configured fields should look like the graphic below:
After setting up the access point we click "Deploy", after all the data has loaded Google will ask us to agree to allow the project we created to access our Google account. In order for the project to function properly, we must give our consent.
After a while, the "New deployment" window should appear, and in it the ID of our deployment and the direct URL to the access point. Both of these values are individually assigned to the Google account and we should not share them anywhere, the account on which we present the tutorial's operation was created exclusively for this purpose - that's why all the data is preserved.
The URL of our access point should be copied, we will need it to create code on the Micromis Base V1 board.
Currently, the URL we will use for the tutorial is:
https://script.google.com/macros/s/AKfycbxNgg50yw9BFUv2CP464vh1-IawVx9Km2JSQ7fC6lSAdk1WtRSR19PxPHaeVrZQRPOa/exec
We can check the operation of the access point using a browser. To do this, we need to paste the copied address of our access point into the URL space. For the test we will also need the values of the transmitted variables that we have set in the code for the access point:
In order for the value of the variable to be in the worksheet, it must be properly transmitted using the called URL. For example, if we want to send data information from a sensor having ID 11, which on June 1, 2023 at 3:15 p.m. took a temperature of 25.5 C then we need to create a URL termination which will be:
?temperature=25.5&datetime=23-06-01%2015:15:00&id=11
And for data read from a sensor having ID 5, which took a temperature of -1.0 C on November 3, 2015 at 9:00 a.m. we need to create a URL ending that will be:
?temperature=-1.0&datetime=15-11-03%2009:00:00&id=5
The full URL for the first reading should in our case be:
https://script.google.com/macros/s/AKfycbxNgg50yw9BFUv2CP464vh1-IawVx9Km2JSQ7fC6lSAdk1WtRSR19PxPHaeVrZQRPOa/exec?temperature=25.5&datetime=23-06-01%2015:15:00&id=11
And for the second reading:
https://script.google.com/macros/s/AKfycbxNgg50yw9BFUv2CP464vh1-IawVx9Km2JSQ7fC6lSAdk1WtRSR19PxPHaeVrZQRPOa/exec?temperature=-1.0&datetime=15-11-03%2009:00:00&id=5
There were three symbols in the strings that may seem obscure at first, but after a brief analysis it is easy to understand their purpose:
- ?question mark separates the query stringsit signals where the space for the data we send
begins- & -character that separates the attributes we
- %20 - this symbol is nothing but a space in URL encoding, thanks to it the date and time in our document will be in the form:
23-06-01 15:15:00
A no:
23-06-0115:15:00
When we copy one of the URLs with the assigned data we can paste it into the address bar of the browser and click enter, after a while we will get a message that the script was executed but no data was returned:
In addition, when we look at our spreadsheet we should see the data we just sent:
In order to check if more data is added in the next rows, we can send another data packet. After a while it will appear in our sheet.
Once we are sure that the access point and the sheet are working properly, we can move on to discuss the firmware for the Micromis Base V1 board.
Step 4: Analyze the Code
To run the developed software, place the code presented in the tutorial in the Arduino IDE environment. To ensure proper operation of the code, you need to modify the values of the variables located in the initial lines. It is necessary to set the appropriate APN address for the network used. Depending on your needs, you should add a PIN code for the SIM card. It is worth remembering to modify only the values of the variables, not their names, otherwise the software will not work properly.
The first lines of the software contain the configuration of constants and variables that manage the operation of the software. The second and third lines of code are used to assign the Temperature_LM75_Derived library and create an object for it. This library was used because of the use of the LM75 temperature sensor built into the Micromis Base V1 board.
//Include library of temperature sensor
#include <Temperature_LM75_Derived.h>.
Generic_LM75 temperature; //Creating object for library
Also defined in the code are the RX and TX pins of the Quectel M65 modem embedded in the Micromis Base V1 development board, due to the permanent connection of the modem's UART interface together with pins 16 and 17 of the ESP32 chip, we should not change the values of these variables, otherwise it will be impossible to establish communication between the two chips.
//Defines the RX and TX pins for the cellular modem
#define RXD2 16
#define TXD2 17
The variables responsible for proper communication with Google Sheets are the URL and Sensor_ID variables. The Sensor_ID variable stores the sensor ID, which allows you to identify the source of the measurements if you are creating a system built with more than one device. Since in the cache created in Apps Script we did not specify the type of data that will determine the device ID, we can set any text or numeric value as the ID. By default, the Sensor_ID variablehas a value of "1" and is:
String Sensor_ID = "1";
In the case of the ID "Sensor_greenhouse" the variable will be:
String Sensor_ID = "Sensor_greenhouse";
It is worth remembering that these variables will be added later in the code to the URL, so the space in the variable value must be replaced with "%20" so the ID ofsensor with ID "Sensor Garden" should be stored in the variable as:
String Sensor_ID = "Sensor%20Garden";
And not:
String Sensor_ID = "Sensor Garden";
Another variable is URL, which stores the URL of the access point, this is the same address that we copied earlier from Apps Script, in our case the URL variable is:
String URL = "https://script.google.com/macros/s/AKfycbxNgg50yw9BFUv2CP464vh1-IawVx9Km2JSQ7fC6lSAdk1WtRSR19PxPHaeVrZQRPOa/exec";
It is worth remembering to include in the variable only the copied address, without additional characters, otherwise the device will not be able to connect to the previously created access point.
After entering the appropriate URL and creating the device ID, we need to check whether the SIM card placed in the Micromis Base V1 board, requires a PIN code to be entered when the modem starts working. If the SIM card requires a code then it should be entered into the variable SIM_CARD_PIN_NUMBER. For a PIN code of "1234", the value of the variable should be:
String SIM_CARD_PIN_NUMBER = "1234";
If the SIM card does not require a PINat startup then the value of the variable should be empty.
The last item to configure is the address of the access point(APN), which is used by the mobile network operator whose services we use. This address should be placed in the APN_ADDRESS variable. The most common access point address in many countries is "internet", for this value the variable will be:
String APN_ADDRESS = "internet";
For example, for the T-mobile network in the Czech Republic, the APN address is "internet.t-mobile.cz", so the value of the variable will be:
String APN_ADDRESS = "internet.t-mobile.cz";
We can easily check the APN address of a particular operator using the apn.how website.
In the following variables, the program sets the pin that allows the modem to start and the operational variables used during the code's operation.
The setupModem function
The setupModem function is designed to start the modem. To make sure that the modem is already on, the program sends an AT command and then checks that the response contains the word "OK." This signals that the modem is ready for communication.
If the modem is off or unresponsive, the function activates it by setting the MODEM_PWRKEY pin to high for 1000 ms. When the modem is turned on, the program sends the ATE1 command to enable echo mode. This mode causes the modem to send all generated data to the UART interface.
The function then reads the data from the UART interface and looks for the word "Call Ready," which means that the modem is ready for communication.
If the modem does not start up correctly after 10 attempts, the function restarts it with the PWR_KEY pin and resets the attempt counter.
//Function to turn on a modem
void setupModem()
//Read any available data from the modem's serial interface
download_data = Serial2.readString(); //Reading data from modem UART
//Check if the modem is already on or not
Serial2.println("AT"); //Send command to check if modem is on
if(download_data.indexOf("OK") > -1) //Waiting for "OK" response from modem
// Modem is already on
Serial.println(); //Print blank line in Serial Monitor
Serial.println(download_data); //Print data from modem UART
Serial.println("Set modem startup:"); //Printing information in Serial Monitor
Serial.println("Modem is aleady on"); //Printing information in Serial Monitor
download_data = ""; //Clearing variable
else
//Modem was off, turn it on
Serial.println("The modem has been switched on"); //Printing information in Serial Monitor
digitalWrite(MODEM_PWRKEY, HIGH); //Turning ON modem by setting power on PWR_KEY pin through 1000 ms
delay(1000); //1000 ms pause
digitalWrite(MODEM_PWRKEY, LOW); //Turning OFF PWR_KEY pin
Serial2.println("ATE1"); //Set echo text mode on modem
int initial_counter = 0; //Blank initial counter
while(download_data.indexOf("Call Ready") == -1) //Waiting for "Call Ready" response from modem
Serial.println("Waiting for modem init"); //Printing information in Serial Monitor
delay(500); //500 ms pause
initial_counter++; //Increase the counter value by 1
if(initial_counter > 10) //Trying to turn up modem again
The configurationModem function
The configurationModem function configures the modem by sending a series of AT commands to it via the serial interface (Serial2), which has been previously configured.
The AT commands that will be sent during the configuration function enable the modem to function properly. Among these commands are:
ATV1 - enables descriptive mode, which allows the modem to send detailed responses to commands sent to it.
AT+CMEE=2 - enables extended error reporting, which results in more detailed error messages when a command fails.
AT+IPR=115200 - sets the baud rate to 115200 bits/s, which is the rate at which data is sent over the serial interface.
ATI - retrieves modem information, such as manufacturer, model and firmware version.
AT+QNITZ=1 - activates time synchronization with the mobile network.
AT+CTZU=3 - configures the storage of time downloaded from the mobile network in the modem's RTC memory.
AT+CPIN="PIN code" - enters the PIN number if the SIM card requires it to unlock the SIM card.
AT+GSN - retrieves the modem's IMEI number, which is its unique identifier.
AT+CIMI - retrieves the modem's IMSI number, which is also its unique identifier.
AT+QCCID - retrieves the modem's ICCID number, which is also its unique identifier.
AT+QICSGP=1, "APN address" - sets the APN address, which is the name of the access point.
The modem's responses to the sent AT commands are read and stored in the download_data variable and displayed in the Serial Monitor. When the configuration is complete, the function displays information in the Serial Monitor about the completion of its operation.
//Function to configure the modem
void configurationModem()
Serial2.println("ATV1"); //Set verbose mode on
Serial2.println("AT+CMEE=2"); //Enable extended error reporting
Serial2.println("AT+IPR=115200"); //Set baud rate to 115200
Serial2.println("ATI"); //Get modem info
Serial2.println("AT+QNITZ=1"); //Synchronize time from GSM network
Serial2.println("AT+CTZU=3"); //Update network synchronized time to RTC
if(SIM_CARD_PIN_NUMBER != "")
{ //If SIM card requires a PIN, enter it
Serial2.println((String) "AT+CPIN=" + SIM_CARD_PIN_NUMBER);
Serial2.println("AT+GSN"); //Get IMEI number
Serial2.println("AT+CIMI"); //Get IMSI number
Serial2.println("AT+QCCID"); //Get ICCID number
Serial2.println((String) "AT+QICSGP=1,‖. + APN_ADDRESS + "ƒ"); //Set APN address
delay(100); //100 ms pause
Serial.println("MODEM HAS BEEN CONFIGURED"); //Printing information in Serial Monitor
NetworkCheck function
The networkCheck function is designed to check the status of a mobile network connection.
To check the status of network registration, the function periodically sends the command AT+CREG? to the modem. The response returned by the modem identifies whether a connection to a national or roaming network has been established. If connection problems are detected, the function re-executes the modem's configuration. In the case of a connection to a roaming network, the modem will return a response of "+CREG 0.1", and in the case of a roaming connection "+CREG 0.5".
In addition, the function can help detect SIM card problems. If the message "SIM card error" appears while testing the program, it is worth checking whether the SIM card in the Micromis Base V1 is operational.
//Function to check status of cellular connection
void networkCheck()
Serial.println("Network test"); //Printing information in Serial Monitor
int connecting_count = 0; //Blank initial counter
while (download_data == "") //While download_data variable is empty
Serial2.println("AT+CREG?"); //Send command to get network registration status
if(download_data.indexOf("+CREG: 0,1") != -1) //Check if device is registered on home network
Serial.println("Network registered - home"); //Printing information in Serial Monitor
delay(50); //50 ms pause
break; //Quit from while loop
else if(download_data.indexOf("+CREG: 0.5") != -1) //Check if device is registered on roaming network
Serial.println("Network registered - roaming"); //Printing information in Serial Monitor
else if(download_data.indexOf("+CME ERROR: SIM failure") != -1) //Check if there is a SIM failure error
Serial.println("SIM card error"); //Printing information in Serial Monitor
else if(download_data.indexOf("+CME ERROR: 13") != -1) //Check if there is a SIM failure error in CME numeric form
else
Serial.println("Connecting to network"); //Printing information in Serial Monitor
connecting_count++; //Increase the counter value by 1
if(connecting_count > 75)
setupModem(); //Check that the modem is working properly
configurationModem(); //Make configuration again
Serial.println("Some network connectivity issues... trying to connect again"); //Printing information in Serial Monitor
delay(5000); //5000 ms pause
Function getModemTime
The getModemTime function is used to retrieve the current date and time from the Quectel modem. The function first sends the "AT+CCLK?" command to the modem to retrieve the local time. The function then waits for the modem's response and parses the received data to get the date and time. The function also removes unnecessary data from the modem's response, such as "AT+CCLK?" and "OK," and removes quotation marks and whitespace characters. Finally, the function returns the date and time as a string, which is ready for further processing.
//Function to get time from GSM network
String getModemTime()
Serial2.println("AT+CCLK?"); //Get local time
String date_and_time = ""; //Create variable for storage infomation about date and time
while(download_data == "") //While download_data variable is empty
if(download_data.indexOf("AT+CCLK?") > -1) //Waiting for "AT+CCLK?" response from modem
download_data.replace("AT+CCLK?"," "); //Replacing unnecessary data from modem response
download_data.replace("+CCLK: "," "); //Replacing unnecessary data from modem response
download_data.replace("OK"," "); //Replacing unnecessary data from modem response
download_data.replace("\"," "); //Replacing unnecessary data from modem response
download_data.trim(); //Removing whitespace characters
date_and_time.concat(download_data.substring(0,2)); //Substract year
date_and_time.concat("/"); //Put / symbol into variable
date_and_time.concat(download_data.substring(3,5)); //Substract month
date_and_time.concat(download_data.substring(6,8)); //Substract day
date_and_time.concat("%20"); //Put URL space symbol into variable
date_and_time.concat(download_data.substring(9,11)); //Substract hour
date_and_time.concat(":"); //Put : symbol into variable
date_and_time.concat(download_data.substring(12,14)); //Substract minutes
date_and_time.concat(download_data.substring(15,17)); //Substract seconds
return date_and_time; //Return date and time data
SendUpdate function
The sendUpdate function is used to send data to the Google Sheets access point using the Quectel M65 modem. The function takes two arguments: the temperature value and the date and time. At first, the function sets the connection_established variable to false, and then in a while loop the function tries to establish a connection to the mobile network using AT commands sent to the modem. If the connection is established, the connection_established variable is set to true, and the while loop is terminated.
//Function to uplad data to Google Sheets endpoint
void sendUpdate(float temperature, String datetime)
connection_established = false; //Set connection_established variable as false
while (!connection_established) //While connection_established variable is false
Serial2.println("AT+QIFGCNT=0"); //Set MUXIP function to GPRS
Serial2.println((String) "AT+QICSGP=1,‖. + APN_ADDRESS + "ƒ"); //Set APN for your cellular provider
Serial2.println("AT+QIREGAPP"); //Start TCPIP task
if(download_data.indexOf("OK") != -1) //Waiting for "OK" response from modem
Serial2.println("AT+QIACT"); //Bring up connection with GPRS
Serial.println("Modem is connected to cellular network."); //Printing information in Serial Monitor
connection_established = true; //Changing variable value to exit from while loop
else
Serial.println("Modem not connected to cellular network."); //Printing information in Serial Monitor
Serial2.println("AT+QIDEACT"); //Deactivate current GPRS context
The function then creates a valid URL containing information about the temperature, date/time and sensor ID. Once the URL is created, the function establishes a connection to the Google Sheets access point and sends the data over an HTTP connection.
Serial.print("Temperature: "); //Printing information in Serial Monitor
Serial.println(temperature); //Printing temperature in Serial Monitor
Serial.print("Datetime: "); //Printing information in Serial Monitor
Serial.println(datetime); //Printing time and date in Serial Monitor
String current_URL = String(URL+"?temperature="+temperature+"&datetime="+datetime+"&id="+Sensor_ID); //Creating a valid URL including temperature, date, time and sensor ID
Serial.print("Google Sheet URL: "); //Printing information in Serial Monitor
Serial.println(current_URL); //Printing URL for connection in Serial Monitor
int URL_length = current_URL.length(); //Measure URL length
Serial2.println("AT+QHTTPCFG="requestheader",0"); //Disable header requesting in HTTP connection
Serial2.println("AT+QHTTPURL=" + String(URL_length) + ",80"); //Send information about URL address and timeout of this connection
Serial2.println(current_URL); //Send URL to modem via UART
Serial2.println("AT+QHTTPGET=80"); //Create HTTP GET request
while(download_data.indexOf("CONNECT") == -1) //Waiting for "CONNECT" response from modem
Serial2.println("AT+QHTTPREAD=80"); //Reading data from server
The following AT commands are used in the function:
AT+QIFGCNT=0 - sets the MUXIP function to GPRS
AT+QICSGP=1, "APN address" - sets the APN address for the mobile operator
AT+QIREGAPP - starts the TCPIP task.
AT+QIACT - activates GPRS connection
AT+QIDEACT - deactivates the current GPRS connection
AT+QHTTPCFG="requestheader",0 - disables the request header in an HTTP connection
AT+QHTTPURL="URL length",80 - sends URL and timeout information for this connection
AT+QHTTPGET=80 - creates HTTP GET request
AT+QHTTPREAD=80 - reads data from the server
sendUpdate also checks whether the connection to the Google Sheets access point has been established correctly, and displays the relevant messages on the serial monitor if it fails. The function also displays information about the transferred data and URL on the serial monitor.
Setup function
This is a configuration function that is called only once at startup. The function configures the serial ports and I2C devices, sets the MODEM_PWRKEY pin as an output and starts the GSM modem. When the modem is turned on, it calls the function that configures the GSM module's settings and checks its network connection.
void setup()
Serial.begin(115200); //Start main UART interface
Serial.setTimeout(100); //Set timeout for main UART interface
Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2); //Configure and start Serial2 UART interface
pinMode(MODEM_PWRKEY, OUTPUT); //Set MODEM_PWRKEY as output
Wire.begin(); //Run resources for I2C temperature sensor
Serial2.setTimeout(100); //Set timeout for Serial2 UART interface
setupModem(); //Run GSM modem
configurationModem(); //configuration GSM modem
networkCheck(); //Check status of cellular connection
Loop function
The syntax of the loop function is based only on a cyclic call to the sendUpdate function, which sends the data to the Google Sheets access point, then waits a minute for this task to be performed again.
void loop()
sendUpdate(temperature.readTemperatureC(), getModemTime()); //Send data to Google Sheet endpoint
delay(60000); //Wait a one minute
Step 5: Test
Then click the "upload" button to test the program!
Note: If you get an error while uploading the program:
"A fatal error occurred: Failed to connect to ESP32: Wrong boot mode detected (0x13)! The chip needs to be in download mode".
Just hold down the "boot" button until you see the "Connecting... " message in the output window. This should solve the problem.
Step 6: The Effect of the Project
After creating a place for the data and adding the script to Google Sheets, we will gain an access point to which, using the Micromis Base V1 board and the software discussed in this tutorial, we will be able to send sensor data.
