Introduction: Transform a Ps2 Steering Wheel Into a Wii Steering Wheel
In this instructable I will show you how to transform a common ps2 steering wheel into a wii steering wheel.
This wheel can also mounted on a table and give you reverse action.
Sorry for my bad english
I am from Hellas
I am from Hellas
Step 1: Things You Are Going to Need
A PlayStation 2 steering wheel
A Wii remote
Some duct tape
A dremel
Something soft
A screwdriver
A scissors
A Wii remote
Some duct tape
A dremel
Something soft
A screwdriver
A scissors
Step 2: Take Apart the Steering Wheel
Use a screwdriver to take apart the steering wheel
Then remove all the parts that are in the wheel
Step 3: Cut the Wiimote Socket
With a dremel tool cut in the front part a hole to put your wiimote
Be careful not to cut the hole wrong because you will destroy the wheel
Step 4: Make Sides of the Hole Soft
Whith the sand paper dremel tool or with a sandpaper make the sides as soft as you can
Step 5: Prevent Wiimote From Scratching
Put duct tape on the sides of the hole to prevent the wiimote from beeing scratched
Step 6: Put the Parts Back Together
Re-assemble the steering wheel and put something soft into the hole
Step 7: The Final Step
Put the wiimote into the whole.
If it is not fit then widen the whole a little.
Step 8: Usage
You can now use the steering wheel in 2 ways
1st.Not screw the helm back to the main body
2nd.Screw it nai mount it on a table so as you do not get tired when you play a game
Thanks
Thanks
