Introduction: Transforming LEGO Aircraft Carrier
This project started innocently enough with a drawing I made. I'm sorry that I don't have it on hand, but I drew an concept sketch of an aircraft carrier, then drew it as if it had transformed into a humanoid. Like all of my other drawings, it disappeared, but the concept revisited my brain later. Naturally, I used Lego bricks to try and make my dream a reality. My final design was not like my picture, but it worked just the same.
The main problem I had was size. I wanted my carrier to be small enough to take around, not easily done when a lot of moving parts are needed. I originally did a 3 stud wide model which failed miserably. I realized it had to be larger.
Secondary problems were creating arms that bent, a bridge that created a head, and feet.
This Instructable is largely pictures as instructions, but I may have some text in each step.
This is the final product! I hope you enjoy. Please comment below! I am always welcome to some constructive criticism!
Step 1: Parts
Here is a list of elements needed. I apologize is any of the names are incorrect.
- amount: element type
- 1: 1 x 4 plate
- 1: 1 x 2 cheese wedge
- 1: 1 x 2 grille
- 1: 1 x 3 plate
- 1: 1 x 1 plate
- 1: 1 x 1 plate with vertical clamps
- 1: 2 x 3 plate
- 2: 2 x 1 plates
- 2: 2 x 4 wings
- 2: robot levers
- 2: robot arms w/ studs and vertical clips
- 2: "T"-bars
- 2: 1 x 2 plates with segmented bars
- 2: 1 x 2 smooth slopes
- 2: 2 x 2 plates with a right angle (this piece is a 2 x 2 plate with a 1 x 1 piece missing)
- 3: 2 x 4 plates
- 4: 1 x 1 plates with horizontal studs
- 4: 1 x 1 plates with horizontal clamps
- 6: 1 x 1 plates with vertically pointing clamps
- 8: 1 x 2 plates with bars on the short end
Step 2: Bow (front)
- Place 1 x 4 plate on flat surface.
- Put 1 x 2 plate with segmented bars on the thinner end of the plate.
- place another 1 x 4 plate on top of the first. A one stud long overhang should be present.
- Place both wing pieces on top of the last piece, covering it completely. The wide end should be facing the segmented bar.
- place a 1 x 4 plate on the 1 x 2 plate.
Step 3: Stern
- Arrange the pieces as in the first picture.
- Place a 2 x 3 plate on top of the 2 x 2 plate with segmented bar. It should overlap all the pieces, but leave a 1 x 2 sized gap.
- Place a 1 x 2 cheese wedge into the gap. The highest side should face inward.
- Place four 1 x 1 plates with upward-facing clips on the 2 x 3 plate. They should form a square. The clips should be parallel to the sides of the stern. Check the picture.
- Flip over the Stern.
- Attach two robot arms with the bends facing upward on the leftmost two sections on the bar.
Step 4: Bridge (command Center) and Stern-Bow Connection
- Attach a 1 x 1 plate with a vertical clip to the open bar segment. The stud should face inward.
- Attach a 1 x 2 plate to the outer side of the 1 x 1 plate.
- Attach a 1 x 1 plate to the gap on the 1 x 2 plate. The stud faces inward.
- Place another 1 x 2 plate under the last 1 x 2 plate.
- Clip the robot arms on to the Bow. The bars should be directly across from each other.
Step 5: Arms/Hull
- Attach two 1 x 1 plates with outward facing studs as shown.
- Place a 1 x 2 grille on top of the plates.
- Put one robot lever in each hole of the 1 x 1 studs. They should point outward as shown.
- Place one 1 x 2 plate with bars on the short end on top of another. Connect them to the levers as shown. do the same for the other side.
- Attach a 1 x 1 plate with a horizontally facing clamp to the 1 x 2 plate. The studs should face outward. Do the same for the other side.
- Place a 1 x 1 plate with outward facing studs under the 1 x 1 plate on both sides as shown.
- Adjust so the arms are parallel and flush to the body.
Step 6: Bottom/Keel
- Clip the "T"-bars on to the bottom of the Stern as shown.
- Attach the robot arms with suds on the "T"-bars as shown.
- Clip a 1 x 1 plate with a clip on top to each of the robot arms.
- Place one 1 x 2 plate with bars on the short end on top of another. Clip them to the robot arms as shown.
- Place a 1 x 2 smooth slope on to the 1 x 1 plate as shown. Repeat on the other side.
- Adjust legs as shown.
Step 7: Transformation
- Move the legs outward.
- Flip the legs by moving the "T"-bars outward. Make sure the 1 x 1 tiles on the legs are facing outward.
- Flip up the feet.
- Fold the arms out. Flip the bow down to form the chest.
- Flip down the command bridge to create the head.
- Style arms.
- Adjust arms and legs for balance.
