Introduction: Travel Size Double Speaker 2.0
Have you ever been annoyed because your speaker is not working? Or is so bulky you can not bring it on a trip? I have the fix. This speaker is small, but loud. It automaticlly connects to your phone after you connect it once. Have fun!
A wifi module with to places to put in speakers, cardboard, 2 speakers that go in wifi module, hot glue gun, and your choice of paint
Step 1: Making the Base
Measure your speakers. Take out a sheet of cardboard size is your choice, but big enough to fit the two speakers. Cut out holes for both of the speakers. Cut out another sheet the same size but do not do anything with it. Take your wifi module and measure the port on it. Cut out a sheet at least an inch tall, and as wide as the bottom of the speaker sheet. Cut out a tiny hole big enough for the port to slide into. Glue the side on the bottom of the speaker sheet. Make the port fact the speakers, not opposite. Glue on sides with the same length. If you want to, you can add a cardboard handle. Glue the speakers in their holes like you measured. Half-way there!
Step 2: Putting in Wifi
Connect the two speakers and the wifi. Push the wifi module port into the tiny hole you made. Glue the wifi module down, and try to plug it in. The module light should glow if it works. If it does not work, try connecting it with your phone. Take out the sheet of cardboard you cut, and glue it to the back of the speaker. For painting, put paper over the speakers. It will keep them from getting paint on them. Choose what ever paint you want. I would recommend spray paint.
Congrats! You made your travel speaker! Have fun!
