Introduction: Trebuchet Build
A trebuchet is a specific version of the catapult that uses a counterweight to create the force to fling an object from a sling at the end of a pole. A Trebuchet to demes taits the transfer of gravitational potential energy into kinetic energy. Which is why I am building it for my physics Teacher.
- 2 x 4's (Three 8-foot boards)
- 3/4 inch plywood
- 1-inch outside diameter PVC pipe
- 4 2-inch swivel and locking wheels
- 5 1-inch 2-hole pipe straps
- 5/8-inch medal bar with threads
- 4 5/8-inch Hex nuts
- 4 5/8-inch washers
- 2-inch star-bit screws
- 3-inch star-bit screws
- 1/2-inch Phillips-head screws
- 1/8-inch twine/string
- adjustable weight dumbell
- duct tape
- Cheesecloth or other flexible fabric
- 1 nail with no head
The tools
- Miter Saw
- Drill
- Circular Saw
Step 1: Cutting the Wood
Using a Miter saw cut the wood to you desired lengths.
Step 2: Make the Stands
When making the stand I made a frame at the bottom to outline the base and make 2 4 foot boards to make the stand the arm would attach to. I used brackets to screw the the stand to the base and tried to level it before adding the arm.
Step 3: Attaching the Wheels to the Base
i used 4 locking wheels and screwed them into the bottom of my base.
Step 4: Securing the Pivot Point to the Stand
I should of used bolts and a washer but used multiple screws to attach the ball barring to the stand.
Step 5: Making the Arm
I used a 8 foot board and cut 2 1 foot pieces of wood to go around the central pivot point and drilled a hole at the end of one side of the to make the second pivot point. In the future try to make holes level.
Step 6: Securing the Arm to the Pivot Point
I treaded the steel bar through the ball bearings and attached the bearings to the stand.
Step 7: Securing the Weight to the Arm
I made a second pivot point to the end of the arm to attach the weights to. I attached the dumbell to it using duck tape which latter failed to stay.
Step 8: Making the Sling and Pouch
i cut a piece of a bag and so the edges would not come undone I taped them with duck tape then cut 2 piences of string the same length and attached them to the sling.
Step 9: Connecting the Sling to the Arm
I used a eye screw which I tied the sling to connect it to the arm.
Step 10: Firing the Trebuchet
When firing the trebuchet it first worked when only having 2 pounds on the end of the arm. In the second test I uped the weight and the dumbbell started to tear the duck tape that connected it the the arm and eventually did. I will fix the flaws in my project over the summer.
