Introduction: Tree Prop
This is a great way to have a tree in your own home without the mess!
Things you will need,
Expanding foam
Chicken wire
Worsen stake
News paper ( I found a roll of packaging paper that worked well)
Tan spray paint
Brown paint
Black paint
Paint brushes
Fake tree branches
Wire
Hula hoop
Lets get started!
Step 1: The Trunk
F!or the trunk we first need to have a frame. I made my frame from a sodden stake that I stapled heavy duty chicken wire to. Then I got my newspaper and duct taped it around the whole trunk so no Erie was showing. Make sure the newspaper doesn't sag. Now draw guidelines of where you want the bark strips to be. Now with you'd expanding foam spray it on your structure following your guidelines. With a spray bottle spray with water. Then let dry until firm.*when using expanding foam wear gloves* Now the trunk is dry spray with the tan spray paint and let dry. With a paint brush paint black in the gaps of the trunk and where ever else you think it needs to be.
Now let your creative side take roll and do detailing with brown paint. Once dry you have your trunk.
Step 2: The Branches
Now time for the top of the tree. Stab 4 pieces of wire onto the top of the trunk and curl to they won't come out. Now connect the other side of the wire to the hula hoop. With your tree branches zip tie the stems to the hulls hoop in different possessions (some up some down) once you're finished with that then your done! Congratulations!
Thank you!
-Andrew
