Introduction: Tree of Life Photo Edit Tutorial
In this instructable, I will walk you through the process of creating those cool artsy Tree of Life breastfeeding photos. The photos represent the flow of life from mother to child through breast milk.
Edit:
It seems the picsart app had been updated. I will either edit this or upload a new tutorial to reflect the changes.
Edit:
Step 1: Create New Project
Open your Picsart app. Click the plus sign to start a new project. Click edit. Select the picture you want to edit into a tree of life picture. You can use a nursing picture, bottle picture or even a pumping picture.
Step 2: Choose a Tree Sticker
Click the sticker button to choose a tree. You want a tree with no background. There are very few FREE trees like this. You can upgrade your app to premium ($) and get more if you'd like. You can also try removing the background yourself.
You'll need to search for trees. Start with "tree of life" in the search bar. I've also found trees just using "tree" to search.
Step 3: Adjust and Position Tree
You will use the adjustment tools to make the tree the size you want. You will put the tree branches/leaves on the baby's face.
*See next pages for how to combine 2 trees for a better fit.
Step 4: Erase Parts to Combine Trees
Use the eraser to remove part of the tree so that you can combine trees. Zoom in close and change the eraser to 100 hardness to have clean lines. Hardness at 50 will have soft fuzzy edges.
*In this example I removed the roots because I want bigger roots.
Step 5: Optional 2nd Tree
If you are combining trees you will add and adjust the 2nd tree using the tools so that it lines up with the 1st tree. Erase the excess part of the 2nd tree. After erasing fine tune the adjustment.
Step 6: Add Some Magic
Click the magic button to bring up the different artistic filters. Some of my favorites for Tree of Life photos are:
Midnight
Moonlight
Galaxy
Rainbow
Highlight
Midnight
Moonlight
Galaxy
Rainbow
Highlight
Step 7: Finish and Save Your Project
For this sample, I chose the Midnight filter. Click the white arrow in the upper right corner to access the save and share options. Then, click the save button. Finally, click on save to device. You can then share your image wherever you want.
