Introduction: Triangle House
I made a triangle/ winter cabin house.
I used box cutters, a hot glue gun, a safety mat, sandpaper, a measuring stick, wood, pencil, and Styrofoam.
Step 1: The Base
Firstly, cut 3 pieces of thin wood into a length of 12in and a width of 3in (recommended box cutter). Then, using a hot glue gun, line them up equally and glue them together.
Step 2: The Roof
Next, cut out 3 more pieces of thin wood into the lengths and widths (Length-10.5in, Width-3in), (Length-12in, Width-3in), and (Length-13in, Width-3in). After this, hot glue them together, going from smallest to bigger. Then, hot glue the 3 combined wood to the base equally. In addition, cut out 3 more pieces of thin wood in length and width (Length-11in, Width-3in) x2 and (Length-12 in, Width-3in). Hot glue the 11in length and 3in width thin wood together. Lastly, hot glue the combined wood to the base and the original 3 thin wood pieces. And the same is true for the last thin wood piece. But, glue it higher than the other two.
Step 3: The Front
Using thin wood cut 3 small pieces (L-3in, W-1/4in)x2 and (L-1 1/2, W-1/2). Furthermore, hot glue the same L and W pieces to the side of the (L-1 1/2, W-1/2) thin wood. Then make the door (W-1 7/16, L-2 1/2) and hot glue it to the side of the frame. Following this, fill the rest of the front with whatever wood design/ like a puzzle piece-(Your opinion).
Step 4: The Back
Cut two different wood pieces using the dimensions (L-6 1/2in , W 1in) and (L-3 1/2in, W-1in). And attach them to the roof as seen in the picture. Then using Styrofoam, fill in the space to act as a window. But leave the middle open.
Step 5: The Interior
After, all that use small wood pieces to make stairs. (Depending on you on how big you want your stairs)-this part is your opinion. Also, how big you want your base for the house's second floor is up to you. Lastly, hot glue everything to the house to finish the project.
