Introduction: Triangle Mural Wall Design
This Instructable is for a Triangle Mural Wall Design. It is a decoration for our makerspace to brighten up the area and inspire creativity!
MATERIALS:
QTY DESCRIPTION
1 Pencil
1 Large T-Square or chalk line
A/R Primer Paint (Dark or Light depending on the colors you choose)
A/R Latex Gloss Paint in many colors (Primary colors plus black + white if you want to mix a wide range of colors)
1 Small Paint Brush
1 Medium Paint Brush
Step 1: Paint the Triangle Wall Design
First, sand and prime the surface of wall. White primer was used because most of the triangle were light colored.
Second, using the T-square, measure out grid on the wall. This wall started with 2 foot squares, then it was divided in to 1 foot squares.
Third, Decide how you want your triangles positioned. An "X" was made with a straight edge in each 1 foot square.
Fourth, paint each individual triangle painting the three corners with the small brush and the middle with the bigger brush. Painting in groups of the same color helps paint more efficiently. Each triangle too 2 to 3 coats of paint.
CONGRATULATIONS! You completed the Triangle wall mural!
