Introduction: Triangle Robot
Hi All,
In this instructable, I will share, how to make a simple robot at home with a dc geared motor. This project can be used to introduce simple robotics to kids
Step 1: What Do We Need ?
- DC geared motor
- 9V Battery and connector
- Cardboard
- Popsicle sticks
- Skewer or toothpicks
- Superglue
- Cutter
- Soldering iron
Step 2: Prepare : Cardboard
- We need 4 equilateral triangles with 8cm sides and a rectangle with 5cm x 8cm
- I have used box cardboard, which is thick
- Drill holes on the triangle at 1cm from each corner
Step 3: Prepare : Popsicle Sticks
- Cut 6 pieces popsicle sticks of 2.5cm in length each ( cut few extras, just in case )
- Drill a hole 0.5 cm from the edges
- Glue toothpicks on popsicle sticks, on one hole only
- Let this dry for few hours, donot rush
Step 4: Body
- Superglue two triangles and rectangle as shown
- Add support to avoid the triangles bending or moving away from the intended position
Step 5: Assembly
- Superglue two toothpicks on the motor
- Fix the motor in the body, such that the toothpicks can move easily
- Add toothpicks rails, all these should be easy to move, with minimum wobble and friction
- Add the popsicle arms as shown, all arms should make an equilateral triangle to match the holes on the triangle
- Glue the arms in place and leave it to dry
- Make sure you stick the rails and arms not the cardboard
Step 6: Testing
- Add battery and test
- Give it to your kid to play
Note
- Make sure that the cardboard does not get stuck with the toothpicks rails or arms
- There may be friction between rails and carboard
- Replace battery based on motor
