Introduction: Pyramid Slingshot - Simple and Fun DIY STEM Project for Kids
About: I'm a writer, maker, and educator who's on a mission to better the world through hands-on engineering projects. Check out my work: www.stem-inventions.com/
Inspired by the various Viking Catapult designs, I decided to create my own version using the set of materials for all of the other STEM Inventions projects! It's fast and easy to build and super fun to launch!
You can find the lesson plan, 1-page project sheet, and more project ideas at STEM-Inventions.com
Step 1: Materials
The Engineering Creation Kit has everything you need for this project and many more from STEM Inventions.
9 skewers
3 rubber bands
1 plastic cup
1" foam cubes (for projectiles)
Masking Tape (Dispenser)
When you make a purchase through these links, I may earn an affiliate commission at zero cost to you.
Step 2: Make the Frame
Tape three dowels together into a triangle. Repeat to create 3 triangles, then tape those together to form the pyramid.
When forming the pyramid, tape the triangles together near the corners for a sturdier structure.
Step 3: Add the Rubber Bands
Tape three rubber bands onto the frame as shown.
Step 4: Tape on a Cup
Tape the rubber bands evenly around the edge of the plastic cup.
Then wrap a second layer of tape around each connection to ensure the rubber band doesn't rip through the tape.
Step 5: Aim and Fire!
To fire
  • Load your projectiles
  • Place one hand onto the frame to hold it in place
  • Pinch the cup with your other hand, pull back, and release!
Step 6: Safety, Tips and Troubleshooting
Caution! This project can be dangerous! Be sure to reiterate that no one should ever aim the slingshot at another student or something breakable.
  • This design is very simple with a lot of room for modifications. Can it be made smaller? More rubber bands? Can something sticky be added to the bottom to prevent the slingshot from sliding around? What is the best projectile? Encourage your students to experiment and think of improvements!
  • If you are confined to an indoor area, set up a designated launching zone. Have students take turns firing, or have everyone fire at once and retrieve their projectiles at the same time. Setup safe targets to encourage students to aim at a designated area.
