Introduction: Trick Dice
Have you ever gambled with family or friends but you kept losing? Have you ever felt frustrated because of rolling a dice and it wasn’t a number you wanted? We experienced this a lot so we made TRICK DICE. You are probably wondering what that means, this is a dice that will always roll a specific number which we set to ONE. We made it so it doesn't roll one every time, but it is heavily skewed to roll one. It will roll one most of the time, but there is still a chance that it rolls other numbers. The reason we wanted to make this Trick Dice is because when we play Trouble — a board game that has to move every piece to the finish line. And how far a piece can move depends on what we roll on the dice. To make it a " Fair " game, we want everyone to only roll ONE so we can lower the chances of losing the game.
To make this dice we used Autodesk Inventor Professional 2025 to design it. Then we used a 3D Printer to print the dice out. The material of the dice we used was 3D Printer filament.
Step 1: Sketch
Draw a 25mm square
Step 2: Sketch
Use the offset function to offset 1.5 mm wall
Step 3: Sketch
Use the three-point-arc to create a 11.5 arc
Step 4: Sketch
Use the trim function to trim off the parts of the arc that stick out.
Step 5: Extrude
Extrude the drawing 22mm to create the main part of the dice.
Step 6: Sketch
Create a new sketch on the top plane
Step 7: Sketch
Draw two rectangles in order to seal up the dice.
Step 8: Extrude
Extrude the two rectangles to seal up the dice.
Step 9: Sketch
Create a sketch on the top
Step 10: Sketch
draw two construction lines on the surface to find the center point.
Step 11: Sketch Sides
Draw each of these drawings so each of the sides add up to seven.
Step 12: Extrude
Extrude the circles to 1mm down.
Step 13: Chamfer
Chamfer all the inner circles by 1mm
Step 14: Filet
Filet all the edges by 3mm
Step 15: Trick Dice
Done
