Introduction: Triple Single
Looking to take single chains up a notch? If so try making a Triple Single!
Step 1: Materials
For this bracelet you will need:
-a loom
-a hook
-a c or s clip
-LOOM BANDS
-a loom
-a hook
-a c or s clip
-LOOM BANDS
Step 2: Placing the Bands
Place a band diagonally to the left. Then place bands straight up the loom until you get to the second last peg. Here place a band diagonally to the right. Go back to the start of the loom and place a band diagonally to the right. Again place bands all the way up the loom until you get to the second last peg where you will place a band diagonally to the left. Go back to the start and place bands all the way up the loom.
Step 3: Connecting Bands
Put horizontal bands across the loom (look at the pictures for better info)
Step 4: Hooking
Add a capping band to the last middle pin (capping band instructions are on my single chain tutorial) and turn the loom around. Reach in through the pin that you just placed the capping on and grab the first band under the capping band, then bring it forward, onto then next peg. You then reach into that peg and bring the band to the next peg. Continue doing this until you reach the end of the loom. Go back to the pin that you placed the cap band on and grab the next band and pull it diagonally to the left. Again hook all the bands on the left side of the loom but make sure to reach through the connecting band. After this go to the capped pin, to hook the right side
Step 5: Finishing the Bracelet
Put your hook through all the bands on the middle-last peg. You then put a band on the end of your hook and loop it through the bands. (Refer to the pictures for a better explanation). The next step is to simply pull the bracelet off the loom. To extend the bracelet you will need to add a single chain to it. Follow the pictures above.
