Introduction: Triple Spatula
I've created a triple spatula that helps you flip burgers very efficiently. With this product, you can grill a lot more efficiently and won't have to waste time trying to flip your burgers one by one.
All you need is a 3D printer.
Step 1: Base Outline
The first thing I did was outline the handle, the hand pad, and the spatula holder which in this case is 3 spatula holders. I encountered many problems while making this and ended up with this final piece. I spaced out the spatula holders so they don't touch each other. Then I made the handle 4 inches as shown in the picture above. After, I made the pad 2 inches long and 0.6 inches wide. Lastly, I made the spatula holders 0.8 inches long on both sides then tilted them at a 45-degree angle and 0.4 inches then added 3 small neck handles for the spatula which are 2 inches long and 0.4 inches wide.
Step 2: Extruding the Spatula Parts and Face Blending the Hand Pad
After I made the base outline I decided to extrude the handle, the spatula holders, and spatula necks by 0.2 inches while I extruded the hand pad by 0.43 inches. Also, I chose to face-blend the hand pad so it can have smooth edges.
Step 3: Spatula Spoon Outline
Next, I made the spoon of the spatula which in this case, I made 3 of them, and the spoons' dimensions are 2 inches long and 1 inch wide.
Step 4: Extruding the Spoon
Afterward, I extruded the spoons to 0.05 inches and filleted the back corners so they could have a smooth edge.
Step 5: Assembling Everything Together
Lastly, I assembled everything and made the spatula as shown above.
