Introduction: Tripod for Pinhole Camera
Here's how to make a telescoping tripod for a Pinhole camera. It will allow the camera to be held steady to ensure a focused photograph.
It helps in the appreciation of 'old school' photography.
9 Empty Beverage cans
Length of cord
Some paper
Glue
Packing Tape
2 pieces of 9mm dowel
Step 1: Aluminium Sheet
- Make some aluminium sheet by removing the top and bottom of a beer can using a craft knife.
- Cut down the middle,
- Flatten by rolling against an edge.
- Make 9 of these.
Step 2: Oval Tubing
- Secure a couple of pieces of dowel together with Sellotape.
- Wrap with aluminium sheet, previously made and secure with packing tape.
The telescope oval tubing locks at the desired height by rotating one section by a quarter turn.
Step 3: Telescoping Tubes
- Make telescopic tubes by wrapping another aluminium sheet over the previously made tube and securing with packing tape.
- Make a third oval tube by wrapping and securing around another aluminium sheet.
- Make 3 telescopic legs.
Step 4: Feet and End Markings
- Roll up some A4 paper and tightly insert into the feet end of each of the 3 telescopic legs.
- Mark where the tubes are about to come out of each other with a permanent marker.
Step 5: Hinging
- Insert some short lengths of cords covered in glue into the top end of 3 of the tubes as shown to join them together and make flexible hinges.
Step 6: Attach a Pinhole Camera
- Attach a pinhole camera to the top of the completed tripod using blue masking tape. To lock the legs at the desired height, just rotate the tube half a turn.
- You are now 'good to go' to take some fantastic pinhole photos.
Step 7: Camera Holder
Rather than using tape to hold the pinhole camera to the stand, a holder can be made using a couple of beverage cans.
- Cut the top and bottom off 2 cans using a craft knife and trimming with scissors.
- Cut each into 1/3 loop sections and then cut the loops into 2 half. This will make 12 pieces.
- Make each of these 'half moon' a little tighter by rolling against an edge.
- Sandwich them together using contact adhesive to form a laminate of 12 layers of can.
- Attach the holder to the tripod legs to hold the pinhole camera.
