Introduction: Trophy in a Case
I made a trophy case because it's nice to look at.
ONshape
Step 1: Base Sketch
Create a sketch on the top plane and draw a 4x5 rectangle (in INCHES).
Step 2: Extrude 1
Extrude towards the bottom by 0.315 inches. Make sure it's set to "solid," "new," and "blind."
Step 3: Sketch 2 & 3
On the front and back of the face of extrude one, make a total of four 4.5x0.5 inch beams.
Step 4: Extrude 2 & 3
Extrude the faces of the sketches inwards by 0.5 inches.
Step 5: Offset Plane
On the top face of extrude one, create an offset plane that is 4.5 inches from the face of extrude one.
Step 6: Roof and Extrude
On your offset plane, create a 4x5 inch rectangle and extrude it upwards by 0.515 inches.
Step 7: Chamfer
Then you'll chamfer all the edges highlighted by 0.08 inches.
Step 8: Bottom Base
At the bottom of extrude one, create a 5x6 inch rectangle and then extrude by 1 inch.
Step 9: Stencil
On the face of extrude 5 (Your bottom base), write the stencil "3rd Place." Then create a center line to center what you've written. The length of the stencil should be 4 inches, and the edges should be 2 inches away from the centerline.
After that, extrude your stencil by 0.15 inches.
Step 10: Center
On the right plane, create a construction line in the center.
Step 11: Trophy Sketch
On the front plane create the half of your trophy using the dimensions above. Any dimensions work as long as they're within the area of the case.
Step 12: Revolve and Shell
After the sketch, you will revolve the sketch around the center construction line. After that you will shell the trophy by 0.1 inches.
Step 13: Color
After finishing your trophy, color all your remaining parts to whatever color you choose.
