Introduction: Troy and Nick: Changing Windows Firewall and Securing Your Network.
Both of these skills are important tools to have in order to keep your network and personal information protected when using the internet. You may use these skills when your want to communicate with another computer without Windows Firewall blocking the connection, or you don't want some average Joe getting a hold of private information held on your network.
Step 1: Changing Windows Firewall Settings: Step One
Navigate to control panel from the start menu.
Step 2: Changing Firewall Settings: Step Two
Select the option "System and Security".
Step 3: Changing Firewall Settings:Step Three
Select the option "Windows Firewall".
Step 4: Changing Firewall Settings: Step Four
From here there are several firewall settings to change.
These include...
Change notification settings- This will allow the user to change what conditions Windows Firewall will notify them under.
Turn Windows Firewall on or off- Thisallows the user to turn Firewall on or off for both public and private networks.
Restore defaults- This sets the Firewall settings back to the default.
Advanced Settings- This allows you to specify the network permission status individual incoming and outgoing processes have.
Step 5: Changing Firewall Settings: Step Five
For simplicity purposes, select "Turn Windows Firewall on or off"
Select the boxes that you would like to be active on both public and private networks.
If you wish for the Firewall to be on, you can specify (under each network type) if it blocks both all incoming connections and or notifies you when the Firewall blocks a new program.
If you wish for the Firewall to be off for either network type, just select the circle "Turn off Windows Firewall" under the designated network type.
When you have the settings you want, select the "ok"button at the bottom of the screen.
Step 6: Changing Firewall Settings: Step Five
If you prefer specificity, select "Advanced Security".
Here you can select both Inbound and Outbound rules. Under either Outbound or Inbound rules, select the intended connection. Once you've specified the connection you want to edit, select the "properties" option in the right column.
Step 7: Changing Firewall Settings: Step Six
Under the general tab you can specify multiple settings important to security.
You can disable the connection by unchecking the "Enabled" box.
Under the "Action" column, you can block the connection by selecting the circle next to "Block the connection", or you can allow the connection by selecting the circle next to either "Allow the connection" or "Allow the connection if it is secure".
Once you are done select the "OK" box at the bottom of the window.
Step 8: How to Secure Your Router
There are multiple ways to secure your router.
We will show you how to change your routers network and firewall settings.
Step 9: How to Secure Your Router: Step One
Open up command prompt.
Press windows + R and enter "cmd" in the text box.
Hit enter.
Step 10: How to Secure Your Router: Step Two
Type "ipconfig" and hit enter.
Locate your default gateway and enter it into the address bar of your search engine.
Step 11: How to Secure Your Router: Step Three
Login to your router.
Enter the username and password of your router and hit login. Usually the default username is admin and the default password is password. The interface of the router layout will vary depending on the network provider.
Step 12: How to Secure Your Router (Changing the Network Settings): Step Four
Once you are at the home screen navigate to the Wi-Fi settings.
For our router: Gateway->Connection->Wi-Fi.
Step 13: How to Secure Your Router (Changing the Network Settings): Step Five
Navigate to private Wi-Fi network were you will see your network name, MAC address, and security mode.
Select the EDIT button all the way to the right.
Step 14: How to Secure Your Router (Changing the Network Settings): Step Six
Here you will see that there are multiple options to edit for security purposes.
First, you can change your SSID name by entering a new name in the textbook next to "Network Name (SSID)".
Next, you'll see the security mode option. Make sure that it is set to a WPA/WPA2 setting if it is not already the default.
You can also edit the Network Password by entering a new password in the text box next to "Network Password"
And lastly, you can disable or enable the broadcasting of your network name by clicking the "Enabled" box that is next to "Broadcast Network Name (SSID)".
Step 15: How to Secure Your Router (Changing the Firewall Settings of Your Router): Step Seven
Navigate back to your router tool's home.
Navigate to your IPv4 or IPv6 settings under firewall.
For our router: Gateway->Firewall->IPv4/IPv6.
Step 16: How to Secure Your Router (Changing the Network Settings): Step Eight
Once you have reached your firewall settings, choose the strongest level of security and select "save settings".
For our router: "Maximum Security (High)"
4 Discussions
3 years ago
I really enjoyed this presentation and it really helped clear this topic up for me. Thanks for making it now I will get an A on the final.
3 years ago
I like all the pictures, now I can secure my router and stop hackers!
3 years ago
Thank you for the help, the arrows made it very clear as what to click on.
3 years ago
Very thorough walk through, easy to follow. However, some of the pictures are blurry and hard to read.
