Introduction: Tube Man
This is a minature version of the tube man that is mostly used in car dealerships to catch the attraction of new clients.
Materials:
  1. Tissue paper
  2. 9 volt Battery
  3. Tape
  4.  Repurposed fan
  5. Top half of a water bottle
  6.  Alligator cables
  7. Sharpie
  8. Switch
For this project you will not need a lot of things. You are going to be able to find most of the materials at home.
Step 1: Tissue
  • Get tissue paper, measure that everything fits properly in its position before putting together
Step 2: Cut
  • Cut the paper in half and then roll it up a little bit then tape it and make like a tube with one hole on the bottom
Step 3: Battery
  • After doing the little man you start setting up the battery and wires so the fan can be able to function
Step 4: Tape
  • Then tape the wires and the batteries so the fan is able to function and then create a switch.
Step 5: Fan
  • When the fan can be turn on and off then create a base so the fan can go on that base and the base be able to sustain it
Step 6: Little Man
  • Then put the fan on a bottle so the bottle can go through the little man and create the right ventilation needed so the man can stay up.
Step 7: Done
  • Tape the end between the bottle and the man and done. Look at the man being filled with air.
