Tube Sealing Device
Intro: Tube Sealing Device
BACKGROUND STORY
The tube sealing aid is a project for design for everyone. Design for everyone is a cocreation project, where students make products together with a person with a disability. This products solves problems that they experience because of their disability. For the tube sealing aid we worked together with Anthony.
Anthony is 26 years old, he has a mild mental disability and problems with fine motor control. He works in a sheltered workshop where they make chocolates.
His job is to fill tubes and close them. Because of his problems with fine motor control he is having troubles closing the tubes with the current tool. It takes in a lot of time and he result is skew and never the same. The tube sealer is the answer to this problem.
While doing some research, we saw that the problem can be divided into 2 actions. First the tube is sealed on top, afterwards the edge is folded twice. This made us realize that 2 tools could be necessary to solve the problem. For Anthony it is easier to remember what he has to do, if he has different tools for different steps.
HOW THE TUBE SEALER WORKS
First after filling, 7 tubes are placed in a holder. Then they are closed on top with one simple move. After this every tube is folded separately with the folder, and placed in a different holder. As last the tubes are placed in the closer again to make the sealing tighter.
With the tube sealing aid Anthony has the ability to close the tubes by himself. The result Is fast, clean, straight and all tubes are closed on the same height.
MATERIALS (in this case);
- Wood MDF and plywood
- Hinges
- Screws
You can choose different materials depending on the use. For Anthony the wood will be replaced with solid volkern, to respect the food safety regulations.
TOOLS
- Drill
- Drill bit, diameter of the tubes
- Saw
- Milling machine or dremel
- Cutter
- Sandpaper
- Screw driver
STEP 1: Parts for the Tube Folding
PART 1 & 2
The easiest way is to make part 1 and 2 in one time and after milling cut in two parts (see drawing). The two parts will be nicely aligned. Dimensions x and y can be define by you and Z is dependent on the material thickness.
L = length of the tube
D = diameter of the tube
X = min. 2 x the lenght of the hinges + D
Y = min. L
PART 3
Small hinges with matching screws
PART 4
PVC, thickness 1 mm
STEP 2: Assembly of the Tube Folding
The PVC sheet is at the front of part 2 and fixed with screws
Part 1 and 2 are put together with hinges
STEP 3: Parts of the Tube Sealing
PART 5
The milling rectangle has the dimensions of part 8 and is 2 mm deep
PART 6 (2x)
Min. lenght of the tube x lenght of part 8 x thickness of the material
PART 7 (2x)
Min. lenght of the tube x min. width part 8 x 18 mm
PART 8
Bar with some holes for the tubes
The holes = diameter tube
PART 9 (2x)
Hinges
STEP 4: Assembly of the Tube Sealing
Connect part 6 and 7 together, see last picture
Connect part 5 to 6 and 7 with a hinges
9 Comments
threeoutside 9 years ago
Very nice project. Good on you!
snakelips1 9 years ago
Fikjast Scott 9 years ago
Great work
shazni 9 years ago
So well done :-)
techie54 9 years ago
jessyratfink 9 years ago
So simple but it works so so well. Great work!!
nodcah 9 years ago
Nice instructable! I like the picture labels! :-)
boatingman 9 years ago
Mmmmmmmm! Chocolate.
Lorddrake 9 years ago
Well done all around.
