Turn Lead Into Gold, With Modern Alchemy
Intro: Turn Lead Into Gold, With Modern Alchemy
Here is my video on how to do this is you don't wanna read it.
STEP 1: Step 1: Respect the Chemicals
CAREFUL: If you are not somewhat skilled in chemistry I recommend you NOT attempt this. It is quite toxic, and I don't recommend anyone try it. This is downright nasty stuff, I can't say it enough, just watch the video for fun!
STEP 2: Step 2: Seriously, Respect Them.
STEP 3: Okay, Good. First What You Need!
Reagents:
Lead Nitrate (also nasty)
Potassium Iodide
Baking Soda
STEP 4: Mix the Reagents
Once mixed, it looks like cheese.
STEP 5: Heat the Solution to 100C
It should go clear, but if you see this, it is not a saturated solution, and you should increase the heat, OR add more water.
STEP 6: While It Cools, It Does a Very, Cool 'golden Rain' Effect
STEP 7: Filter It, and Let It Dry for 2ish Days
Filter with coffee filters, using gravity, or attempt a vacuum filtration with an extremely fine frit, or a buchner funnel.
STEP 8: Store This Pretty Stuff!
Don't forget to label it, and clean up with LOTS of baking soda.
19 Comments
THECOLD 3 years ago
limitlesspotential 5 years ago
The only way to truly change elements into Gold is by a Nuclear Reaction, you need MASS amounts of energy to change the composition, for example via means of transmutation as seen in 1941 by changing Mercury into Gold https://journals.aps.org/pr/abstract/10.1103/PhysR...
Why bother doing the experiment on this page, its about as useful as making a potato clock
amirul.habibie.burriedmyheartcauseofu 5 years ago
this not possible same as chemical composition.
SuperGeek17 6 years ago
I have not yet done this experiment. This is really cool because it does not require transmutation circle. It seems cool, will be reporting back when I have done the project.
Snipewing 7 years ago
CollegeChemistry 7 years ago
I listed them in the video, but it CAN be done 1 to 1, but Lead Nitrate NEEDS to be used up, so I did a 1: 0.8
nanosniper 7 years ago
this was super cool idea????????????????????????????????????????????????????????????????????????????
w.... what?
youngscientist 7 years ago
rainingfiction 7 years ago
But can you sell for $1,259.00 per ounce? That is the real question
knowledge is without price... So really this is worth the moon.
Arn't you the spokespersons? :P
hubi 7 years ago
One day too late, for this 1st April Joke
gm280 7 years ago
If only you could turn lead to gold, I would be a billionaire.
If this worked I wouldn't share it!
jtobako 7 years ago
But you can...at about a billion dollars an ounce.
