Introduction: Turn Old Pallets Into a Chicken Tractor!
Here's the ~9-minute video version:
What Is A Chicken Tractor?
A chicken tractor is a movable chicken cage, allowing you to keep your chickens under control while still moving them around the yard.
Why Would I Want One?
-Have your chickens till and weed your yard
-Buy less food for your chickens
-Eliminate your need for petroleum-baed fertilizers
-and, last but not least: make your chickens happy!
WARNING: please see the warning below about my use of tools in the video. This is NOT meant to encourage you to use tools beyond your skill level, and I'm not going to try and defend the safety practices (or lack thereof) in the video. Be careful, take responsibility for what you do, and don't chop your fingers off:)
Where Can I Learn More?
Here are 3 resources you may find helpful if you choose to dive into the pecking world of chicken tractor design:
-General overview of raising chickens, including square feet per bird
-Pictures of much-groovier-looking tractors
-A $690+ but stylish commercial alternative
Step 1: Gather Your Materials
You'll need the following supplies:
-~4 wooden pallets, or something else to create the 'skeleton' of your structure. These are in the garbage outside large grocery and department stores pretty much anywhere. You want the oldest, ugliest ones you can find that are still more or less intact. I used pallets that were about 45"x35", but size is flexible. It'll make your project easier to have 4 pallets of the same size (the 5th is just torn apart for scrap wood).
-Chicken wire, or something else to keep your chickens in and cats out. This is available at any home improvement store.
-Something to shade your chickens from the rain. I used a piece of an old plastic tarp that I had laying around my yard.
-Something to secure it all together. I used staples, both 1.25" with a compressed air staple gun and .25" with a hand-powered gun.
And I used the following tools:
-Saw-zall (my favorite tool of decontruction:))
-Table saw (both this and saw-zall can be replaced by any decent hand saw + some extra patience)
-Hammer and crow bar (to separate the 5th pallet into usable scraps of wood)
-Utility blade (to cut the tarp; scissors would also do the trick)
-Hand-powered staple gun (used to secure the tarp, as the air-powered staple gun goes right through the plastic)
-Air compressor with staple gun and nail gun (overkill: a hammer with a coupla nail and some 1" staples would definitely work)
Of course, you can improvise widely on this. Just try to avoid buying (and polluting via the manufacture of) something if you can find a free, reused version (like the pallets).
Step 2: Prepare Your Pallets
I have chosen to cut my pallets in half and remove unnecessary support slats. Please be more cautious with your use of a table saw than I was! Here's how I did this:
1. Cut your pallets in half. My 10" table saw cut deep enough to separate the halves on most sections, and I finished the others with the saw-zall.
2. Cut the middle support with the saw-zall, making sure the separated halves don't land on your foot.
3. Remove unnecessary wood from the side of the pallet that looks like a picket fence. Save these: you'll use them in the next step
Step 3: Create the Tractor Frame
I chose to make my frame 2 pallets long x 1 pallet wide, with the vertical being the shorter dimension of the individual pallets.
To connect the pallet sections together, I used the pieces of wood that we removed in the last step and an air-powered staple gun. Other methods of attachment will work as well, just keep in mind that you're dealing with used, lower-quality wood that splits easily. It's probably a good idea to stick with thinner (higher-guage) fasteners, whether you're using screws, nails, or staples.
Order of connection doesn't matter, just make sure to line up the pieces before connecting them together. I found it helpful to attach my joining piece to one of the pallets and then just align this assembly with the other pallet, rather than trying to grow a third arm:)
I overlapped onto the bottom section of the split pallets more, to strengthen the pallet's joint as much as possible.
To further strengthen the design, I added a cross-piece on top by using the thicker wood in the middle of a pallet. Because this wood wasn't long enough to reach across the tractor, I nailed 2 pieces to a small (~8 inches) board to join them together.
Step 4: Make a Gate
This part's a bit tricky if you try to be a purist like I did and construct your gate hinge out of bits of a pallet. The challenge is to create something that keeps the gate from being pushed out from the tractor frame (the chicken wire keeps the frame from being pushed in) while still allowing you to slide the gate on and off of the chicken tractor to dock your chicken tractor against the coop. If you're up for the challenge, check out the pictures below and the video to get a sense for the hacked-together wood shim arrangement I used. Otherwise, I recommend cheating by using 2 hinges and a latch:)
Step 5: Chicken Wire All Over
Next, coat the chicken tractor and the gate with chicken wire. This was a breeze to attach with the air staple gun, but you can use many different methods.
Some tips:
-The more tension you put on the wire, while stapling, the nicer the coop will look. Create tension by pulling away from the area you'd like to make taut: if i'm nailing the upper-right corner of a chicken wire ractangle, I'm pulling up and to the right while I staple.
-Make sure you don't attach wire to the end of the tractor on which you're placing the door, unless you want a road to nowhere:)
-If you're buying chicken wire, purchase wire of the same height a your tractor: this will save you cutting the wire down to size.
Step 6: Create Some Chicken Shade
You wouldn't want to hang out in direct sun all day, and you're (probably) not covered with feathers. So, treat your chickens to a little refuge from sun and rain by attaching a impermeable barrier to the top of a section of the tractor. I covered about a third of my tractor roof with a doubled-over piece of plastic cut from an old tarp I found, and my chickens seem pretty happy with this. My air stapler went right through the plastic, so I used the hand-powered stapler to attach my roof.
Step 7: Test Chicken Acceptance!
You're now ready to bring in the flock! You or your beautiful assistant can herd, throw, or otherwise prod your friendly poultry into their new home. If they're extra lucky, you'll even provide food, water, and a return to the coop at the end of the day.
Some enhancements you may want to make:
-Add wheels to one end to make the tractor easier for one person to move.
-Offer your neighbors a chicken-based lawn maintenance service.
-Create a 'chicken tractor roomba,' using solar power to move the chicken tractor around your yard. Of course, you'd have to name this Robot Chicken:)
Congratulations on your new superhip recycled chicken tractor, and be sure to send me a picture when you're done!
The Instructables Book Contest
45 Comments
8 years ago on Introduction
You sir do not need to be near power tools, but I like your idea!
My hat's off to you. Working with pallets is a pain in the neck. Advice to anyone who goes this route that pallets take time to take apart if you want the end product to look nice. Also gather more of them than you think you will need. Even for chicken tractors.
8 years ago
I like it but I like a chicken tractor
10 years ago on Introduction
*chuckles* Every time I hear the term, I think of a rooster on the seat of an old Massey-Ferguson!
Great video, man. I also use old pallets for many of my building projects. I am wanting to build a chicken tractor to allow my bird to ( free range ), while still remaining safe from predators. I have one concern though. I would love to see more videos from ya in the future, so lets get rid of that table saw.. Very scary! Thanks for the info.....
14 years ago on Introduction
we made one of those. except its a triangular rectangle(whatever the heck its called, i failed geometry the first time so give me a break) its about 2 feet tall, 3 feet wide and 6 feet long. we have bantam chickens, thats why its smaller. but we have wheels on it and we just slide it around the yard.
Reply 13 years ago on Introduction
it called a rectangular primid
Actually it's called a "triangular prism" -- rectangle bottom and sides, triangle front and back.
http://math.about.com/od/formulas/ss/surfaceareavol_6.htm
A rectangular pyramid looks like the Egyptian kind, but with a rectangle on the bottom instead of a square. (Those are kinda hard to build out of wood -- so many non-right angles! But the triangular prism is fairly easy -- lay two rectangles together, voila! This is how I made a couple greenhouses out of glass doors -- hmm, maybe I should make an Instructable about it!)
Kiki -- a Montessori child, where geometry begins at 2.5yo :) (We thought the geometric shapes were fun to play with, but they were sneaking learning into all we did! :) )
Reply 11 years ago on Introduction
Kiki, thanks for the link about rectangular prisms...and the idea about the greenhouses made out of glass doors. Would you mind elaborating on that? Or make an ible, please?
thanks, Nina
11 years ago on Step 7
Wonderful idea and great use of discarded materials, but using a table saw to cut pallets is wrong on so many levels! As an avid woodworker, I can't imagine a more dangerous stunt - please don't ANYONE (professional or not) try this at home! Not only do you risk permanent physical damage up to and including death - you also risk damaging a multi-hundred dollar machine building a $20 tractor. Go for the handsaw or sawz-all. They work great and are much safer! The two prime directives in using a table saw are BE SAFE and NEVER cut anything that might have metal buried in it (and all pallets do!). My philosophy is that DIY is great for everything except suicide! :) Thanks for the idea, though, my son and I are talking about options for a chicken tractor - this one is definitely in the running! Gary
cool
This is perfect! I built a chicken coop for my wife and now I was looking for plans for a chicken tractor. We even have old pallets laying around. Thanks for sharing.
12 years ago on Introduction
That video was terrifying.
Here's some advice just to save you time and supplies: anything you can do with 5 nails, you can do with 2. they really don't provide much structural support.
Just...be careful next time.
FLATULATIONS--Hey Guys, I counted--he still has all of his fingers, a pleasant personality and this instructible will hopefully make some happy chickens. My yard birds: 15 chickens, guineas, and five Peafowl all roam the many-acre yard. The chickens return to their night-time cage at sunset, line up on their roosts and wait for me to close the door. I live in the woods and anything that sleeps out at night will be supper for the predators: Raccoons, foxes, possums. The peafowl sleep way up in the tops of the tall pines and can take care of themselves. Liseman has done a service to those with limited space for their yard birds. And Norml has given me some good ideas for predator control. (Now where did I put my M-6 potato launcher)? Oh, for the dog that kills chickens try this south Florida solution: Wire the dead chicken around the dog's neck. Let it stay there until it rots off, about a month. The dog will be so miserable it will let the yard birds peck a flea from between it eyes an not even growl...forever. Love these "Ibles."
Reply 12 years ago on Introduction
One tip I just read was to paint a stripe of Syrup of Ipecac down the backs of your free range birds. One mouthful and the critters will drop the bird! BARRRRRFFFF!
Good for training chase happy dogs too!
13 years ago on Step 7
Thank you, thank you, thank you for a wonderful instructable on how to do this. I have some chickens, and for now I am keeping them in my glass house (when they are not free ranging during the day), but come summer that won't do. Now to figure out how to build a coop for them!
I'd use a skill saw rather than a table saw...
I DID IT! Well actually I did it a while ago. It has a nice door and two wheels for rolling it around. Unfortunately, we gave away our chickens because they weren't laying any eggs. Well heres the a picture of my pallet chicken tractor...
Chickens stop laying after two years usually. You rebuild your brood by letting some of the eggs hatch if they got fertilized. Good luck with future birds.
My chickens are going on 5yrs and still averaging an egg every to every other day. Breed has a lot to do with it. Go for Buckeyes or Cochines. I also have Jersey Giants, but they need to be close to a year old before they'll start to lay. Even my few Dark Cornish meat hens are still laying after 5 years.
Expect a no or few egg stretch during the winter while they molt (which they start to do around 2. They'll recover and start laying again.
