Introduction: Turn Your Drinking Habit Into Hat Hooks!
Do you enjoy wine, champagne or perhaps a nice glass of bourbon? Do you have a head that sometimes needs to be covered? Why not turn those leftover corks and lids into some nice hooks to hang up your hats?
This project will use a left over lid from a bottle of bourbon, a dowel (2 sided) screw and a drywall anchor to create a unique hat hooks. The lid I am has a little personal memory for me so having it on the wall is both functional and nostalgic.
Lid or cork.
Dowel (double sided) screw. Here is a link to Amazon but please check your local hardware store first.
Hillman 726 Dowell Screw 5/16 x 2 1/2 in. 10-Pack - https://a.co/d/9QOL8K9
Drywall anchor. Exact type depends on where you plan to hang your hook. My hats are not that heavy so a basic one I had laying around was used.
You will also want a drill and drill bit and a pair of plyers.
Step 1: PAR-TAY TIME!!
The first step is to get a drinking! Time to make that lid/cork no longer necessary...
Step 2: Pre Fit the Screw
Using your drill, pre drill a hole into the cork part of the lid. Try to keep the hole straight and not too deep.
To make it easier to attach later I go ahead and put the screw into the lid
Step 3: Put the Anchor Into the Wall
Mark your spot on the wall where you want the hook to go.
Drill a hole in the spot and as your anchor to the hole.
Go ahead and unscrew the screw from the lid.
Step 4: Time to Screw Things Together
Using the plyers as needed go ahead and attach the screw to the anchor. I screw it in a little over half way in.
Once it is where you like it go ahead and hand screw the lid into the screw on the wall.
Add a hat and your done. Phew that was hard work, you deserve a drink!
Cheers!!!
