Turn Your Old CRT Computer Monitor Into a Fish Tank ! ! !
371,719
459
297
Introduction: Turn Your Old CRT Computer Monitor Into a Fish Tank ! ! !
About: Church, Family, Work, Play.
Talk about a great screen saver! I've been wanting to do this build for a while now. Just about every time I see and old CRT computer monitor by the side of the road on trash day I think to myself ...that would sure make a cool looking fish tank. So here is my first attempt at turning and old computer monitor into a fish tank.
Step 1: Gather Your Materials.
Materials
An old CRT (Cathode Ray Tube) computer monitor
Plexiglas (I use 1/8 inch)
Two part epoxy
Clear bathroom/kitchen grade silicone caulk
Paint for the background of the tank
Duck Tape
Hot Glue
Permanent markers
Expanding insulation foam
Tools
Safety glasses or face shield
Thick work gloves
Hammer
Screwdrivers
Utility knife
Rotary tool with cutting bit
Pliers
Speed square
Measuring tape
etc. ...whatever works
Step 2: Removing the CRT
I began by removing the old speakers attached to the side of the monitor by unscrewing two bolts on each side. I then promptly plugged then into my ipod. They worked great giving me amplified music to work by.
Next I removed four screws that held together the plastic housing, opened it up, and removed the monitors guts...very interesting stuff. The Cathode Ray Tube its self was attached to the very front of the plastic housing with four more metal screws that I, of course, removed (make sure you save all the mounting screws as you will need them later).
Step 3: Keeping the Curve.
WARNING - the Cathode Ray Tube is in vacuum. Breaking the tube can be VERY DANGEROUS. If you are to attempt this please be sure to wear proper safety gear (eye protection/face shield, gloves, etc.).
When I began this I was really hoping to be able to simply cut/drill a hole in the top part of the CRT, clean out the inside, caulk the back where the cathode is, and then fill it with water. BOY WAS I WRONG. Long story short, there is a big metal screen inside the CRT and I cracked the glass beyond repair, but who knows maybe I will try again sometime now that I have gotten a better look at the inside of the CRT.
Luckily, after my failed attempt at putting a fairly large hole in the CRT, the front of the tube was still not cracked. So it was up to me and Mr. hammer to get rid of the excess glass.
Once the excess glass has been removed you will need to remove the metal screen. Do not use a grinder to do this like I did. There are metal studs that go through the glass and using a grinder will cause the metal to expand and then the glass to crack. The metal screen can be removed by pressing down and over on the screen support clips.
Now that the metal screen is out the screen needs to be cleaned. I used some WD40 and an old t-shirt rag and it seemed to do the trick. Be careful the stuff on the screen flakes off a lot and is probably not very good to breath in, so wear a mask and turn your shop-vac on to catch as much of the flake/dust as possible.
Next I went a head and put some duct tape around the edge of the glass to soften the edge and keep it from biting me.
Step 4: Plexiglas Is Your Friend.
Okay, so I decided to use the front of the glass CRT as the front of the fish tank and make the rest out of Plexiglas. Begin by measuring, measuring, and some more measuring. See what will fit inside your monitor (Chances are that you will change these as you build, but you need to start somewhere right?).
When cutting Plexi you can score it deeply with a utility knife and then snap of the pieces. On the other hand, if you are fortunate enough to have a band saw, you can just measure, mark, and cut. In my experience, using other saws require a special blade otherwise the Plexi will splinter or crack. Anywho, measure, and cut out you pieces, then lay them out I use some small pieces of duct tape and taped them together to see what it was going to look like. Remember, the front of you tank will be curved so the front of your Plexi should also have a curve to it. Try as best you can to match the curve of the glass. Once I had all the Plaxi pieces cut and ready, I layed all the pieces flat, mixed up a batch of two part epoxy for plastics, and glued the three sides and the bottom together using a little duct tape to hold them in place while the glue set up.
Step 5: Painting a Background.
I did not want to look at the dull gray plastic of the inside of a computer monitor, so the next step I did was to paint on the OUTSIDE of the Plexi fish tank. I began by taking a silver Sharpy permanent marker and a speed square and I drew out some circuit board lines (again on the outside). I then to a green Sharpy to add some shadows under those lines. Finally I masked off the edges and spray painted the OUTSIDE with some cheap green spray paint (of course you could paint whatever you would like to).
Step 6: Access Panel.
To make the access panel I used a rotary tool with cutting bit and carefully cut along the top edge of the top of the tank. This allowed it to be secured by slipping the, already present, tabs under the front part of the plastic monitor housing.
Step 7: Attaching Plastic to Glass.
After many test fits, I went ahead and mixed up a batch of two part multipurpose epoxy, spread it on the front edges of the plastic tank, as well as on the glass front, and then maneuvered the tank into place. I then put a few pieces of scrap wood inside to push against the plastic in order to bow the edges. This effectively curved the edges out to the edges of the monitor and then let it cure. While the epoxy was setting up I added some hot glue around the outside of the tank in an effort to fill gaps and to create a better fit.
Step 8: Fill-er-up!
I felt it wise at this point to test fill the tank. Good thing too because it leaked! So now what? Well I first tried hot glue.... It still leaked. Then, after searching my workshop, I found a partial tube of clear bathroom/kitchen grade silicone caulk. This seemed to do the trick, of course if you happen to have a tube of aquarium sealant that would probably work better. After a few more test fills and leak checks the tank was ready to be returned to the monitor housing.
Step 9: Lighting.
For lighting I picked up a small fluorescent bulb that fits into a regular light bulb socket. Also, after searching the basement I found an old heat lamp that I could use for the fixture. To keep the light bulb from falling in the water I cut a small piece of 2 inch PVC pipe, cut a groove in it for the lights switch to fit, sanded one side, and then used some super glue to glue it to the underside of the access panel. The power cord for the light goes out the back of the computer just like the monitor power cord normally would. The tube for the bubbler worked in much the same way, with the tube coming out the back.
Step 10: Water Support.
Begin by returning the tank to the monitor housing and securing it with the screws you originally removed. Next make sure your lighting and air lines are in place. At this time it would be a good idea to fill the rest of the computer housing outside the tank with expanding insulation foam. When it cures this will not only insulate your new tank, but more importantly, it will support the weight of the water that the Plexi is attempting to contain. My concern here is that if there is no support under the plastic tank it may rip away from the glass front.
Step 11: Finishing Up
Fill your new tank up with water, add gravel, rocks, fish, etc., plug in and enjoy.
Extension ideas:
Make a clear plastic hood to keep any water from splashing up to the light.
Connect the light switch to the on button on the monitor.
Be the First to Share
    • Game Design: Student Design Challenge
    • Big and Small Contest
    • For the Home Contest
    297 Comments
    QueenQuill
    QueenQuill
    13 years ago on Introduction
     Damn you!  I had this idea many years ago, and always wanted to do it.  Then I saw the Instructabled "Dead PC" contest and thought that now would be the time to do it!  But noooo...you have to go and do it first!  *cries*  Ah well, I'll still probably build one, because I've wanted one since I first thought of doing it so many years ago!  BTW, good job in the Instructable!
    TheBestBud
    TheBestBud
    Reply 1 year ago
    She was congratulating him, but language girl!
    QueenQuill
    QueenQuill
    Reply 1 year ago
    LOL... You do realize that this conversation ended a decade ago, right?
    TheBestBud
    TheBestBud
    Reply 1 year ago
    Yep! :)
    Homemadeslop
    Homemadeslop
    Reply 12 years ago on Introduction
    Many have contemplated using crt tv's and monitors for fish tank I thought of this idea years ago with a funny tv show took an old piano and turned that back part into a fishtank or a fishtank holder of sorts. I havent done it cause I know a little to much about electronics including these chunky tvs/monitors. If you still want to do it, then do it you will be the one that uses a bigger or smaller screen, you can customize it as you wish to make it "your own". Just be careful, do outside with a mask might be a better idea than being in the house due to dusts and all.
    faithisroo
    faithisroo
    Reply 13 years ago on Introduction
    yup....i saw that contest too, and wanna make one...but...i guess it's yours...
    T____T
    nice one btw...
    Floyd_Droid
    Floyd_Droid
    Lets be honest... This is an extreme waste of time, money and effort. If you take the amount of money spent + put a price of time it took to create it... you could have bought a very nice aquarium.
    If one still feels compelled to build something like this I would suggest NOT to use the CRT and building the tank directly inside the monitor shell with plexiglass. So that your not risking injury breaking the CRT cleanup and so forth.
    But most importantly is to consider that most fish are very sensitive to chemical contamination: WD40, Glass Cleaners etc... not to mention the phosphor and gases + God-knows-what-else. Unless you want to have a tankfull of goldfish and black mollies... go right ahead. Marine fish would not survive in such conditions.
    1spartan95
    1spartan95
    You have no DIY in you at all. Get off of the internet. NOW!
    TheBestBud
    TheBestBud
    Reply 1 year ago
    Hey! Be nice!!
    VanillaXtiffy
    VanillaXtiffy
    You could say that fish keeping in general is a waste of time money and effort. Not to mention natural resources since in order to keep your fish humanely, you should be doing large weekly water changes.
    pyroarchist
    pyroarchist
    unless your aquarium is extremely overstocked, and tiny anything more than 20 percent every other week is extremely stressful for the fish
    nerfinaticRN7
    nerfinaticRN7
    It's obvious to anyone that read the article that you skimmed it because there is an instructable about safely disassembling a CRT monitor. https://www.instructables.com/id/How-to-safely-disassemble-a-CRT-monitor/ They evidently not used the CRT because the surface is flat. Flat screen monitors use lenslike glass and a flat sheet of glass to do it. That means the fish would look distorted. There is a screen inside every CRT to ceep the electron beam from spreading out too much and/or go off center. So you can't put the fish inside the CRT because shadow masks have miniscule holes in the sheet. Aperture grilles, wich have better picture, have wires instead of miniscule holes, so the water will leak a lot faster. My grandma's CRT monitor has controls on the front, so I can put those controls on the fish tank. They are not simply a menu button, there is contrast, brightness, input format and power as physical switches to put in the tank, so I can turn it into a very nice aquarium. The menu will be an easy feeder where the food will come out of the "electron guns" made of brass. There is my message for you.
    Jack A Lopez
    Jack A Lopez
    Yikes!  Chemical contamination!?
    Does that mean the goldfish isn't safe to eat?
    Nxtfari
    Nxtfari
    Of course it is. Why else would you build it.
    mason0190
    mason0190
    Would this work with one of those gargantuan 56" Sony flatscreens? I have one in my garage (free at a garage sale because two circuit boards were fried) and was waiting for a project like this.
    videogamemaster
    videogamemaster
    Reply 11 years ago on Introduction
    Lol, that'd look so cool. Heh, but I don't think using a flat screen television would work too well (Too thin). Unless it's a chunky one, with the big tube in the back like old school  TVs, then theres possibilities.....
    But I think I'd rather buy/swap out the new cirucit boards and have a big flippin' TV. But thats just me...
    TheBestBud
    TheBestBud
    Reply 1 year ago
    You could also do this kinda thing with an old picture frame and attach a tank to the back, it could be like one of those paintings with eyes that move!
