Introduction: Turn a Laptop Screen Into a Mirror
Hi there, this is my very first instructable, so any critics and comments are welcome ! And sorry for my english, I'm a little frenchy guy =) Some photos are not very good quality, I apologize for that., but they seem clear enough to me.
So, first, What I had was a broken laptop. I tried to use the screen as a normal lcd screen, but it wouldn't work. So I thought I could turn it into something more...useful.
What you need :
- A laptop (hm...broken) or a laptop screen.
- A small cross screwdriver (check the photos)
- A bigger flat screwdriver (actually you could use anything like a knife, as it's not meant to screw here)
- A cutter knife (maybe a thin knife will do)
- A small box (better small boxes) or a glass, to keep the screws
- Approximately 1 hour
Read the whole tutorial before starting, you may want to jump or invert some steps depending on your way of working, or on your equipment.
Now let's get started.
/!\ This instructable doesn't imply cracked screens, it is safe as long as you don't break yours in two, which would require a strong hit. But be careful, as commented S1L3N7 SWAT, "most laptop displays have a small, but still dangerous amount of Mercury in them. It's usually contained in the lamp portion." That means if your screen is cracked, or if you crack it, take it to a recycling agency and be careful about yourself.
What you need :
Step 1: Step 1
First of all, you would need of course to take the screen off the laptop (Photo 1). I don't show you here how to do, because I didn't think I would make an instructable at first ;) but you can find tutorials about that on the web, and it's quite easy.
So, first take off the small plastic masks over the 4 screws in the corners of the screen (Photo 2).
Then just unscrew the 4 screws and keep them safely in a small box/glass (Photo 3). Now here's what we've got (Photo 4).
Step 2: Step 2
Next step is to take the frame off. for this, juste use your fingers, otherwise you'd scratch the screen, a thing we want to avoid. Place your fingers between the screen and the frame, at the bottom of the screen (Photo 1).
Then follow the screen slowly, keeping your fingers under the frame. You should hear small "clics" when the frame removes. Then do the same at the top and sides of the frame (Photos 2 & 3). Be very gentle, not to break one of the clips that hold the frame, like I did : We'll need them. You can now take the frame off (Photo 4).
Now here's what we've got (Photo 5).
Step 3: Step 3
Ok, now we have to take the screws off (Photos 1, 2 & 3). You can unscrew some of them right now, even though it's not necessary at this step. Check the photos.
Then take the screen off (Photos 4 & 5).
Step 4: Step 4
Take a close look at what we've got here. Look at photo 1. We're going to take everything off in a clean way, but you can pull out the wires wildly if you want, as we're not going to use them.
First, let's take off the chrome, black and copper stickers that cover some screws and wires and maintain the wole thing (Photo 2). Actually, taking the whole "stickers" off would be hard and useless. Just use the cutter to cut it along the edge of the frame (Photo 3).
In some points, the sticker can't be cut : don't force on the cutter, that's because there are hidden screws.
Now take the sticker off on the outside edge (Photo 4). Do the same for the black sticker. Now you can unscrew the hidden screws, which are not masked anymore (Photo 4).
Step 5: Step 5
Let's unplug everything now. It's the point where you can just pull out every wire ;)
But for those of you who want to do it the right way :
Look at photo 1. Let's first unplug the pink and blue wires (Photo 2), then the big one stuck by a yellow sticker (Photos 3 & 4). Wasn't a big deal, actually.
Now take a look at the edge of the frame. There are some notches in the plastic, and little pieces of metal are bent into them. They maintain the frame and the screen together (Photo 5). Just use the flat screwdriver to unbend them (Photo 6). They are all over the frame, so be careful to check every one of them. Try not to break them, work softly.
Step 6: Step 6
Here we are. Split the screen and the back of it like shown on photo 1 (just open it in two). Then take off the 6 different sheets that were placed behind the screen (Photo 2). Actully there are 5 sheets and one piece of transparent plastic (Photo 3). Keep the white sheet, put away the others.
Now separate the screen from its frame (Photo 4). There's a sheet of aluminium covering the white plastic frame ; you can just take it off or leave it (Photo 5). I took it off because I dislike not being able to see what I'm doing and working on (Photo 6).
Step 7: Step 7
Now is the final part. We're going to assemble the sheets/screen/frame as shown on Photo 1. If you want a better quality miror, I advise you buy one of the exact dimensions of the reflecting screen, including its width, which is very important. Take the thinnest glass you can find. Otherwise do like me, just reverse the screen inside out.
First put the white frame, in the same orientation as on Photo 1. Then place the white sheet on it. This is because the reflecting screen isn't totally opaque, so it gives a homogeneous background to the "miror". Be sure to respect the helping shapes on the sides (Photo 2).
Then put the screen (Photo 3) and finally the frame. Screw it back (Photo 4). Be sure to bend back the little pieces of metal too (Photo 5).
Step 8: Step 8
Look at your new miror (Photo 1). Isn't it great ? ;)
You can just stop there or, for a more geeky look, put the last frame back.
Ok, now unplug the big Wire -data- (Photo 2) and the thin wires -alim- (Photo 3). For that, just take the sticker off and unscrew the piece of metal. Then unscrew the iron "feet" and take them off the screen (Photo 5). Here's your clean frame ; put back the iron bars on the sides (Photo 6), and then the screen (Photo 7).
Now just clip back the frame (Photo 8), screw it and put the plasitcs masks - mine didn't glue anymore, I had to add glue (Photo 9).
Admire your final miror on Photo 10. =)
Step 9: Outro
I'm not giving you any way of fixing it to a wall or making it hold an upright position. I bet you can figure this out for yourselves...now that the "hard" part's done. ;)
Well this tut is finished (I think) but if you have any question or comment/critics, don't hesitate ! Hope this was some way useful to you.
