Introduction: Turn a Roll of Tinfoil Into the Prettiest Heart Garland
Valentine's Day might be just around the corner but there is still time to whip up this super cute and super easy heart garland! All you will need is a roll of string, a little paint, and a box of tinfoil from your kitchen.
Tinfoil
String
Pink Craft Paint
Step 1: Cutting the Tinfoil
Start by ripping pieces of tinfoil that are approximately three to four inches wide. You will need one piece of tin foil for each heart on your garland.
Step 2: Adding the String Loops
Also, cut one piece of string for each heart. The string should be approximately four to six inches long depending on how far you want your hearts to hang off of the garland.
Loop one piece of the cut string, fold over the edge of the tinfoil and tape the sting in the middle.
Step 3: Shaping the Hearts
Work your tinfoil until you create a heart shape turning the edges of the tinfoil towards the back of the heart. Make sure the string loop comes up in the middle of the heart top.
Step 4: Painting the Hearts
To give your hearts a soft romantic look, paint them with pale pink paint. Make sure to get the paint into all of the nooks and crannies.
As soon as you have finished painting the front of the heart, use a damp paper towel to wipe off some of the paint from the raised areas. This will allow the silver to peek through giving the hearts an aged and worn look.
Step 5: Hanging the Garland
Finally, attach your hearts to a long piece of string and hang your new garland from your mantel or wall. This pretty pink garland will make your heart melt every time you see it.
If you loved this project, check out my new book; Cottage Projects With a Vintage Flair.
To see the original Recreated Designs post with additional photographs, click here...
